So who's done the piston swap?
So who's done the piston swap? UPDATED post 3
i have a few questions?
i ordered diamond pistons standerd bore and ring set with no coatings, cometic headgasket and ARP headstuds...
is there anything else i need? i know i have to drop the pan. and i have gm silicone on order per the dealership!
my main question is this... do i have to drop the crank? cant you just pull the head and pop the pistons out the top with something long and skinny squeezing by the crank?
and do i need new rod cap bolts? if so anyone have the part #?
also, i have seen a few builds were coating were used and they were not there after just a few hundred miles one being ravenss motor... so they were not purchased for 225 extra...
any help will be appreciated...
UPDATE:
things i have acguired:
UPDATE:
thank you so much... thats exactly what i wanted to hear
UPDATE
decided to build motor while waiting for kit
this was so easy please dont anyone be affraid to build there own motor... i have been a mech for 3 yrs but pretty much lived in the garage growing up with pops...
but if you have ever done a head gasket let me tell you this car is so ******* simple to work on its a joke
UPDATE
well i plan on staying on stock cams so i dont really plan on spinning the motor past 7250 and i will be shifting at 7000... so really no need
i will port the head though...
Last edited by hungryhip-ccp; 09-10-2008 at 01:51 AM. Reason: Automerged Doublepost
the piston swap is something i plan on doing... what's the how-to on the neutral balance shaft delete?
check
check
arp assy lube check lol
actually i am going to seens how this car has been out for almost 4yrs and no-one has yet
check
Last edited by hungryhip-ccp; 09-10-2008 at 12:55 PM. Reason: Automerged Doublepost
Need to have the glaze taken off them, moreso if there was any oil getting into the CC.
Just saw this thread...
Black RTV works fine on the oilpan. You'll also need any red gel type sealant if you remove the cams from the head, for the cam end plates.
You do not have to drop the crank. You should however plastigage the connecting rod bearings and replace if out of spec.
Yes, you need new rod cap bolts....part number should be 90537293 I think(have that part number written down but didn't label what it was ). Other TTY bolts that should be replaced are head bolts (ARP ones that I see you have ordered replace these), cam gear bolts and crank pulley bolts.
Coatings are optional, they run fine both with and without them.
thanks...
i forgot to mention i will be flex honing the cyl and replacing rod bolts and cam gear i didnt know about crankshaft
flex hone
is there any kinda upgrade like arp so i dont have to use stockers?
is there a book like chilton or something so i dont have any problems setting up the timing chain
flex hone
Last edited by hungryhip-ccp; 09-10-2008 at 01:25 PM. Reason: Automerged Doublepost
I've used Total Seal's recommended ring gaps for forged pistons when gapping the rings with 0 problems so far on the last engine I did. I didn't for my own engine which is getting new rings hopefully today gapped to those specs, I used slightly wider than stock gaps and its getting more blowby than what I like. If you run lotsa boost though ~25psi+ you might wanna open up gaps a little further though and build a better PCV system. Just imho.
If removing cams, do not use the build books for installing the cam sensor. Theres a misprint in one of them. Line up the marks for the cam sensor and install it while number 4 cylinder is at TDC compression.
Its honestly really hard to screw up the timing if you line up the colored links to the marks on the cams.
One thing to watch though is after you install the head, if you can't get a cam gear to bolt up onto the cam, you probably have the cam installed 180 degrees out of whack. Before moving the cam into the correct position, make sure none of the pistons are at TDC. When you have the crank gear at the 5 o clock position for timing chain install, 1 and 4 will be at TDC, so be careful, do not rotate the cam too much until the pistons are dropped below the deck.
and what did you do for a hone? or did you not hone? i talked to total seal they said a 280 grit then finish with a platue brush or a 400 grit with a six stroke? i think im just gonna do the 400 grit six stroke! what do you think about this?
so you file fitted the rings? and to what clearences? it will be in the specs with the piston right.. i will be running 25 lbs at maximum probably 22-24
No glaze on my first rebuild (it was done at less then 15k miles), machine shop did the others. I planned on breaking the glaze with a 220 grit which most local guys here recommend as it works on pretty much any type ring whether its iron or moly.
Those total seal recommendations might be for gapless rings. The ones you are getting with the pistons are probably not gapless, the should be classic race file fit.
