Something I never noticed
Old Dec 18, 2012 | 09:43 AM
Tjolley's Avatar
Does anybody know of a 2 step rev limiteron the lsj factory pcm???
Well this morning I was driving to work messin with my HP Tuners. And I change the table I never really messed with. And it gave the car rev limiter while the clutch was pushed down.. I've never seen a thread or anybody talk about this
Old Dec 18, 2012 | 09:45 AM
in
Old Dec 18, 2012 | 09:48 AM
Tjolley's Avatar
I'll post up a video later..
Old Dec 18, 2012 | 12:19 PM
wayfarer's Avatar
When I was looking at 'Balts initially, I thought they all had built in NLS, but from reading on here, NLS is only on LNF. When I test drove my LSJ, I did it, and it worked like NLS is supposed to.
now I have an N2MB WOTbox, and I have to shut it off or it pisses me off during "spirited" driving.
so, in for answers
Old Dec 18, 2012 | 12:37 PM
user 72239's Avatar
Why do you need NLS with a LSJ? The whole point is so the turbo can keep boost without respooling. Dont have that problem with the LSJ lol
Old Dec 18, 2012 | 12:38 PM
with hp tuners u can set a sort of like launch control on the lsj
not really a two step, maybe what you did is different
Old Dec 18, 2012 | 12:40 PM
Bad-A-SS's Avatar
What kind of settings do you need to change to do so?
Old Dec 18, 2012 | 12:52 PM
MastaShaKe_88's Avatar
This... but i guess if you're pushin a lotta boost an you wanna do it..
Old Dec 18, 2012 | 12:56 PM
idt he's talking about no lift shifting but launch control, which could definately be useful to us lsjs
Tjolley's Avatar
i just discovered it this morning on my way to work..
Old Dec 18, 2012 | 01:00 PM
ya i feel ya.. a WOT box twould be better tho, otherwise you wont be able to do the whole shotgun effect outta your tailpipe while revvin
Old Dec 18, 2012 | 01:32 PM
wayfarer's Avatar
please correct me if my thought process is misguided, but anything you can do (thinking drag racing) to reduce transition time during gear changes is a plus on the strip.
during a normal manual gear change you lift off the throttle for two reasons-- so the rpm doesn't spike while there is no load on the engine, and to allow the shafts in the transmission to come close enough together in speed to allow the gears to mesh.
using NLS provides a during-the-shift rev limiter that should shorten manual gear shift times
Old Dec 18, 2012 | 01:42 PM
Tjolley's Avatar
it would be sick to get to the line flip a switch and the throttle would be held wide open. unless u hit the brakes.
just hit the clutch and shift the gear
Old Dec 18, 2012 | 02:49 PM
wayfarer's Avatar
who was it that was looking at the clutch hold down / release adjuster thing a week or two ago?
the ultimate drag machines don't need the clutch pedal-- autos > Lenco / planetary manual > traditional stick shift
but manual trans is so much FUN.....
but consistency wins bracket races....
so mixing up both -- running your manual trans car, but getting some help; launch control, NLS, clutch switch, could end up being a lot of fun! , and, just maybe you could win a few extra rounds at the bracket races.
Old Dec 18, 2012 | 02:57 PM
Tjolley's Avatar
mrb found the hydraulic version of it
Old Dec 18, 2012 | 06:26 PM
MyOtherSS's Avatar
makes hitting gears easier, keep your foot to the floor without having the tach buried between gears.
Old Dec 18, 2012 | 06:37 PM
nhanson's Avatar
You sure you werent just boucning limiter?
Old Dec 18, 2012 | 06:48 PM
mrbelvedere's Avatar
what do you think happens with a wot box you set the launch limit rpm and bounce off of it just like how he set it up in hpt
Old Dec 18, 2012 | 07:10 PM
Tjolley's Avatar
just getting off work ill post up a video in a lil..i got 1.30 drive home
Old Dec 18, 2012 | 07:11 PM
nhanson's Avatar
Thought they were different.
Old Dec 18, 2012 | 07:23 PM
c130aviator's Avatar
i am looking through my VCM editor and I dont see it? I have a 2007 also... Do you have newer version of VCM? mine is 2.23.474
Old Dec 18, 2012 | 07:28 PM
Tjolley's Avatar
mine newer than that..
its not lable 2 step or launch control..
Old Dec 18, 2012 | 07:50 PM
which do you have, the website only has 2.22 as the newest and mine is newer than that.
Old Dec 18, 2012 | 08:07 PM
hp tuners forum has some mention of it on a post on the first page dated a couple days ago but the guy said there is a P/N way under the fuel section of the engine tab.
Old Dec 18, 2012 | 08:11 PM
Tjolley's Avatar
bingo..so u can do it
