Spacer plate for meth?
Old Jul 30, 2009 | 08:05 PM
flash13brandon's Avatar
I haven't seen a thread about this so sorry if it has been discussed. But I'm interested in the ZZP spacer plate for spraying meth after the sc. Couple questions. Obviously the adapter plate is better as far as IAT2s, but is it worth it and are there any cons to using it? Also, what is the best way to plug a hole in the intake. I'm running meth already via tap into intake, but I'm not seeing the results I hoped for regarding IAT2s.
Old Jul 30, 2009 | 08:10 PM
nicksredline's Avatar
well i would not say its because of where its tapped but more or less other things
1. how much timing did u add? 2. What kinda mix( ratio OR %).
Old Jul 30, 2009 | 08:21 PM
Even when I only added a couple degrees, the iats were still not what i wanted. Im running close to a 50/50 mix. Granted I live in FL so its 90+ degrees everyday. I know it will be more efficient because the sc is what heats up the iats, therefore spraying directly into the IM will be better obviously. But 130 dollars better is my question?
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
