Spark Plug gap questions
Old Mar 20, 2008 | 03:11 PM
Rodimus_Prime's Avatar
So Ive picked a plug out to run with the car 1 stage colder and copper I know the basics of spark plugs black is too rich, white is too lean and so forth.
I know you cant gap irriduim plugs, coppers dont last, etc
So really what I want to know is how you determine the proper plug gap to run. Stock is .040 but ive been told with the 1 step colder some have problems and closed it to .038.
What "problems" are they talking about and what symptoms do I look for in trying to determine if things are at the right gap
Old Mar 20, 2008 | 03:12 PM
HackAbuse's Avatar
subscribed, can never have too much info about this stuff
Old Mar 20, 2008 | 03:13 PM
redlineblueline's Avatar
i just run ngk v powers in the lsj with either a .04 or a .035 gap i dont remember which one it is
Old Mar 20, 2008 | 03:15 PM
HackAbuse's Avatar
I run NGK Coppers in my 2.2 cobalt, 2 step colder (BKR7E), stock gap, daily driven
They run pretty good.
I need to check them pretty soon though to see how they're holding up
Old Mar 20, 2008 | 03:55 PM
come on man lol thats not helping
Old Mar 20, 2008 | 04:01 PM
i would have to pull them to tell you
Old Mar 25, 2008 | 10:38 AM
well plugs have arrived, i guess ill go with .040 and see how that works out
Old Mar 25, 2008 | 05:54 PM
BKR7Es went in today and now im getting more knock retard than before
im gapped at .040, input is welcome im a bit puzzled if anything there should be less retard
Old Mar 25, 2008 | 06:25 PM
Sizzle06's Avatar
You might have to just find the right gap for your car.What works for someone else might not work for you.(Oh,by the way you can gap iridiums)
Old Mar 25, 2008 | 07:39 PM
well the stock plugs were at .040 with little or no knock
now i got the 1 stage colder with .040 gap and im getting significantly more knock, which direction do i go?
Old Mar 25, 2008 | 07:51 PM
Sizzle06's Avatar
What are your mods?
Old Mar 25, 2008 | 09:16 PM
well this is interesting pulled my 20k old stock plugs , they are gapped at .035
guess ill try that with the new plugs
well set the gap to .035 less knock but still more than what i had with the stock plugs err im about ready to just put the old ones back in
Last edited by Rodimus_Prime; Mar 25, 2008 at 09:16 PM. Reason: Automerged Doublepost
Old Mar 29, 2008 | 11:47 PM
ok update
got new plugs again in stock plug heat range and same gap as stock only difference is copper instead of platinum and now im getting knock above 13psi WTF this never happened with the stock plugs, Am I getting spark blowout?
This is starting to look like more trouble than its worth using anything other than exact stock plugs
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
