Spark Plug HELP!
Spark Plug HELP!
Ok so I just went to NAPA and bought myself some NGK spark plugs (BKR7EIX)...but since I've got them I've heard 2 different stories....One saying Copper plugs are better, and another saying iridium are the best...??? Whats your take on this guys? I want to install these tonight....
ooohhh you will hear everything man. Both sides have great areguments. I personally had bad luck with NGK BKR7e. Got Zex pluggs and they are great. One of my buddy had the same exact experience with the same results. So for now +2 Zex pluggs.
Remember Canadian gas isnt the same as americans, so as far as pluggs go, take american opinions with a grain of salt
basically they offer the same performance.
copper has very very very slightly better conductivity. but its neglegable.
the difference is basically price and longevity.
Copper is cheap, but dont last as long
Iridium conversely, are pricey, but will last alot longer.
basically thats it
basically thats it
should pop my knuckles and get my flame suit on ... damn this thing is chared ... anyway.
The deal is that iridium has a higher resistance to heat which is great by itself especially for drag setups however, to that same great ability once they get hot ... they stay hot and having to have a hotter spark at the same time doesn't help. This is because the very same property that makes them resistant to heat makes them retain heat. So lets say you go on a road course one day and run the car hard, you run the risk of pre-ignition due to the excessive heat built up over time especially in boosted cars.
Copper while less resistant to heat, does not need as hot a spark and has the ability to literally cool off faster, yes spark plugs do have a small window in which they will be allowed to literally cool off namely when they aren't sparking and the chamber isn't igniting a small window but one non the less, allowing the car to run harder longer with a much lower risk of pre-ignition.
In calculations iridium is superior in heat resistance but also pales in comparison to coppers ability to cool off quicker before the next spark and coppers ability to run a cooler spark.
hopefully this thread doesn't end up like the battles of the past ... my head is still ringing from all the arguments
they are gaped at 40 and they swear up and down u dont need to i also called them and they told me not to cause they could break and they are gaped for our cars and i believe its true i have had them in my car all summer long and they droped my temps a lot so for the price they work great
Ok I installed them, and they didnt come gaped .40 out of the box...but that is what i gaped them at. I can notice a little bit smoother idle and acceleration/deceleration. I'm overall pretty happy....but to top it off I got home today and my CW upper and lower billet grills were in!!! YAA.
yeah I used to explain it better but then people got confused and thats when the fighting started. So now I keep it simple to avoid that confusion. Copper is better overall.
The main reason I use the iridiums is because they actually hold heat. Since I rarely go WOT I like the iridiums to help keep the combustion chamber cleaner. If I was going to be running the car hard all the time I would definately go with the copper plugs.
please remember that both plugs offer copper cores.
well some may not.....
but most good plugs will be a copper core with either a nickle tip or a platinum tip or iridium or some combonation of above...
precious metals offer longevity over nickle.....
just make sure heat range is proper for your application.. gapping is proper and the plugs in question have a copper core? nickle tips wear faster..... Platinum and iridium wear slower
i was told not to gap my iridiums, and i wanna put them in now, but all i have is a 3.1 pulley running on stock equipment, so can i throw them in? and imma be useing the same plugs for when i get my stuff installed this weekend like, 2.8 pulley and 60# injectors, so i have to gap these bad boys?
