Spark plug question
Old Jun 11, 2007 | 10:10 PM
Jephron's Avatar
Spark plug question
Alright I got stage 2 exactly a week ago and like everybody else I have noticed the car isn't running as smooth with the stock plugs so I ordered some BKR7E's. I get to parts source to pick them up and what I get is BKR5EG's he did mention that he might have to get the platinum tip equivalent of the BKR7E's but didn't mention this when I called to confirm the plugs were in before driving to pick them up. I ended up not taking the plugs, because the guy there couldn't confirm that they were equivalent, I would think that the platinum tip equivalent would be BKR7** I asked them to re order the BKR7E's tomorrow (they can get them same day from their warehouse) Does anybody know what the difference between these two plugs is, and how exactly to break down NGK's part numbers into terms that make sense?
Old Jun 11, 2007 | 10:28 PM
Johnboy12358's Avatar
No idea, but i am getting the Zex plugs this weekend, putting them in for my next oil change...
Old Jun 11, 2007 | 10:29 PM
Mikey851's Avatar
On NGK's website they did not have a BKR5E"G", but they did have a BKR5E and it appears to be the same as the BKR7E, except that there are different applications listed for that plug. Check out their website.
Edit: Okay so I found their nomenclature. The difference between the BKR5 and the BKR7 is the heat range. That guy had step hotter plugs for you: that would have been horrible. Thank god you didn't take them and use them. The scale is from 2 to 12; the higher the number the colder the plug.
Old Jun 12, 2007 | 07:09 AM
Jephron's Avatar
thanks I'll check it out myself today when they call back. I just thought somebody may have had a similar experience. and may even be using these plugs if they are as close as parts source says they are
Old Jun 12, 2007 | 10:28 AM
Mikey851's Avatar
They are the same plug design but they are a step warmer. This is the opposite of what you want and it would cause detonation.
Old Jun 12, 2007 | 11:51 AM
Jephron's Avatar
are you saying that the plugs are a step warmer than the BKR7E's or are a step warmer than stock. I just got off the phone with them and they say that going platinum actually makes the plug a step colder, so to get the equivalent of a BKR7E in platinum you have to go a step warmer. Plus in my orignal pose I messed up the part number, what they got in is actually BKR5EGP, aparently nobody stocks the BKR7E anymore. Although that is probably just this store
Old Jun 12, 2007 | 03:46 PM
Mikey851's Avatar
I don't think they know what they are talking about as far as the steps warmer or colder. All that represents is how far the insulator protrudes into the combustion chamber deciding how much heat it transfers out of the cylinder.
The BKR5EGP is 1 step WARMER than STOCK. You need a plug which is one step COLDER than stock. You don't have to take my word for it; just search the forums and read NGK's website and nomenclature and it is absolutely apparent:
Website "spark plug 411": http://www.ngk.com/sparkplug411.asp?kw=Platinum&mfid=1
The nomenclature is at the very bottom of the page.
Old Jun 12, 2007 | 03:50 PM
p7x's Avatar
p7x
NGK's held up for a year but didnt look so good when I replaced them with Zex pulgs. Checked the zex plugs last weeekend and besides a lil brown ceramic they look good.
Old Jun 12, 2007 | 03:52 PM
Mikey851's Avatar
The tannish ceramic is a good sign.
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
