spark plug question
Old Jul 29, 2007 | 05:29 PM
bl0wnbalt's Avatar
spark plug question
what are the differences between the colder degree spark plugs? for what reason do you need a colder plug?
Old Jul 29, 2007 | 08:04 PM
blueta's Avatar
Well what heat ranges for a spark plug means is it's ability to remove heat from the combustion chamber. It's determined by: the length of the center insulator, the ability of the nose to absorb and transfer heat, and the material of the insulator and electrode. A colder spark plug will have a shorter insulator nose. It's important because if you are knocking from too much heat in your combustion chamber it'll help remove it more efficiently. BUT the temp in the tip has to remain between 450*C-850*. In other words, if you don't need them don't use them
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
