spark plug torque????
Old Jun 1, 2007 | 08:21 AM
TxLonghorn#1's Avatar
Does anyone know what torque to torque the spark plugs at? And also, what about the torque for the spark plug wire bolts??
I'm in NEED of this ASAP........PLEASE......someone
I'm getting knock and I just hand tighten the bolts
Old Jun 1, 2007 | 08:22 AM
Acidangel_5.0's Avatar
no torque specs.. just make them snug.. dont tighten like hell or you will crack the plug.. just make is snug
Old Jun 1, 2007 | 08:25 AM
cobi's Avatar
1/4 turn past hand tight, thats the rule Ive always followed and it even says to do that on the NGK box. and spark plug wire bolts? I take it your talking about the coil pack bolts those can be a little over hand tight as well.
If your getting knock try re-gapping your plugs first, you may want to switch plugs if you cant get that to work.
Old Jun 1, 2007 | 08:27 AM
so why am I pulling -10.0 to 8.0 of timing and I'm getting P0300???
Old Jun 1, 2007 | 08:29 AM
cobi's Avatar
what plugs are you using?
Old Jun 1, 2007 | 08:30 AM
silversccoupe's Avatar
Ignition Coil hold dowm bolts = 89 in/lbs
Spark Plugs = 15 ft/lbs
This info from GM Sevice Manual pg 6-1383
Everyone should own a set of these,they are extremely hand to have
Old Jun 1, 2007 | 08:32 AM
BKR7E...i THOUGHT THESE WERE THE BEST ****** PLUGS
Thanks Silver.....
Last edited by TxLonghorn#1; Jun 1, 2007 at 08:32 AM. Reason: Automerged Doublepost
P0300 is a very broad code, it said Misfire, not Bad plugs.. two different things..
look at the car in a broad sense.. is it continous or a 1 time thing.. car drive normal now or acting weird? look at all symptoms.. not just 1 code it slung
Old Jun 1, 2007 | 11:11 AM
P0300 is the only code. It'll come up one day.....stay on for two....then one day three it'll go away. but then it returns?
What would be the reason of -10.0 to 8.0 of timing? Is this good?
Old Jun 1, 2007 | 12:19 PM
Halfcent's Avatar
I'm old school
Misfire is not knock. In fact, its almost the exact opposite. How do you know what your timing is? I assume you have a programmer? Have you messed with it?
Old Jun 1, 2007 | 01:23 PM
p0300 can be caused by quite a few things... coil/sensor/vacuum/gas/injectors.... its a very broad error code
Old Jun 1, 2007 | 03:26 PM
Mikey851's Avatar
Yeah how are you monitoring your knock retard?
Old Jun 1, 2007 | 03:36 PM
an0malous's Avatar
did you gap the plugs before installing?
if so what is your gap at.
misfire sounds like you either have them gapped to wide, or maybe assumed they are gapped right out of the box?
Old Jun 1, 2007 | 04:02 PM
ItalianJoe1's Avatar
I just installed a set of those, working perfectly, same as the first set. They came factory gapped at .32, I opened them up tp .35 and thats working good for me. Hand tighten the plugs then give them 1/8 of a turn, just enough to make them tight. DO NOT OVERTIGHTEN YOUR SPARK PLUGS!!! IF YOU HAVE TO PUT ANY EFFORT INTO TIGHTENING THEM, THEY ARE TOO TIGHT.
DarrenGC
Dec 24, 2021 01:55 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
