Which Spark Plugs to get.....
Alrighty, im still on the stock pulley but I have a tune, intake and exhaust and I was wanting to replace my plugs! So I am asking should I get some stock replacement plugs or upgrade to a range colder plugs? Also if I stay w/ the stock plugs what is the code name so I can get direct replacements? I have been to the local autoparts stores and alls they seem to have is AutoLites and if im correct our stock plugs are NGK's so what should I do?
If you are still on stock pully stay on stock plugs cause you dont have to a smaller pully they dont even recommned a colder plug with the gmpp stage 2 kit but you should stay with stock until you get a smaller pully
I am running one range colder plugs that are NGK copper core which don't lsat as long but displace heat much better and give you a better spark. I have some mods done CAI/exhaust but don't think stock plugs are bad unless you go to a smaller pulley. As for mine I might think about goin gback to stock till i get the stage 2 but have no problems with the colder one s now..
Faster heat dissapation, helps cool down cyl temps, reducing chance of detonation.
Too cold can cause incomplete cleaning of the plug, resulting in fouled plugs though. Its all about finding the right gap and temp range for the specific engine combo.
Last edited by ItalianJoe1; May 2, 2007 at 12:08 PM. Reason: Automerged Doublepost
i have stage 2kit, and 2.7 pulley and a few other mods but i have the stock spark pluggs do i need to change my pluggs and if so which exact pluggs do i need]
It probably wouldnt hurt to get 1 step colder plugs
I would recommend either of these, they are both awsome plugs.
1. NGK BKR7E copper plugs gaped to .35
2. ZEX part number 82003-4, no need to gap.
