speedo slow?
ok use to my 3rd gear went to at least 117-120. now it only goes to about 100 or so since my turbo swap. but the swap shouldnt effect anything should it. i mean top speed in each gear is in conjunction with the gear ratio right? is my speedo just slow to read everything? i know our tach can be sometimes. anyways thanks guys.
by the way on a 57 trim im getting full spool by 3800-4000 and pulls like a mofo. had to let some air out the tires but it helped with grip a bit. |
it wont mean poop. has your rev limit changed at all? 100mph in 3rd is 6500 rpm's. i shift at 7250rpms and go to about 111-114 i think. maybe when you got tuned your tuner changed the rev limit? different size tires could make a differen ( i mean the height/ sidewall, not the width of the tire.)
3rd gear does not go to 117MPH, with a 7K RPM rev limiter it stops at like 105MPH. Id say your speedo was off before and now its working fine.
when my car was down for 2 mon for my turbo build the car felt completely different in every way but really it was just cause i hadent drivin it for 2 mon...
Originally Posted by hungryhip-ccp
(Post 3252179)
