Spraying Meth Thru TVS???
So for you TVS guys running methanol/water, are you spraying before the s/c or after? I'm just kinda iffy about spraying it into a $2000 blower; like what kinda effects will it have on the rotor coating, etc.
The coating will just natural wear off too. I would make life easier and just do it before. These work really well on the tvs because while they are more efferent than the stocker they still heat the air up pretty good.
anytime you are able to decrease the inlet air temps another 50-100 degs after the blower you can run way more timing and usually pulley down to the next size down pulley.
