sputtering at high rpm
Old Feb 22, 2010 | 11:13 PM
blk06cbltss's Avatar
so the other day here in wa i got my maf a lil wet and threw a code like always and i usualy just dry everything then kill the power to the car(pulling of the red wire to the bat) then start her back up and everything is back to normal. well my buddy decided to plug his code reader in and deleted the cel using the code reader and ever since then my car has been sputtering like its not getting enough fuel once i get up to 4.5 - 5k rpm and its really pissing me off cuz i cant haul ass now. my car has the zzp stage 2 kit with the 2.9 pulley 49lb injectors and their pcm, then the normal cai, downpipe, catback. help me out guys.
so i decided to check my afr and im usualy hittn like 11 10.5 and right now its like 11.8 12 something
Last edited by blk06cbltss; Feb 22, 2010 at 11:13 PM. Reason: Automerged Doublepost
Old Feb 23, 2010 | 12:04 AM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Change your plugs and/or check their gap. With a 2.9" Pulley, you'll wanna run NGK BKR7E's... gapped at right around .036-.038, iirc.
I've seen this problem quite a bit recently. Plugs SHOULD solve it. Hard to say without seeing/playing with the car.
Old Feb 23, 2010 | 12:08 AM
i have gapped plugs from zzp and it was running totaly fine til this lil incedent so i doubt its the plugs but i can always check them maybe i fouled on or something
Old Feb 23, 2010 | 12:19 AM
Well, after eliminating the easy stuff... aka Plugs... we'll move on to the harder things. Like your MAF.
Old Feb 23, 2010 | 12:21 AM
383_Stroker's Avatar
Maf is screwed would be my guess.. the code scanner isn't going to hurt it
Old Feb 23, 2010 | 12:23 AM
ok cool cuz he deleted the cel and i was hoping he didnt delet some of the tune or something. there is a ss/sc at the junk yard and i will go get its maf =D
Old Feb 24, 2010 | 03:50 AM
sundevil07's Avatar
scan it and see if it has thrown any dormant codes, find out what cylinder the misfire is occuring. pull that injector and swap it to another cylinder check to see if the problem follows it.
Old Feb 24, 2010 | 04:14 AM
Maxim_X's Avatar
I can assure you he didn't delete your tune with the code reader. Plugs first. .33-.35 then comeback if the problem persists.
Old Feb 24, 2010 | 10:00 AM
i already tried that and its not throwing any codes
no_ss
Oct 18, 2015 11:58 PM
patooyee
Oct 15, 2015 05:11 PM
Slick_Nick
Sep 28, 2015 09:15 PM
Trav3480
Sep 28, 2015 02:46 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
