SS Aftercooler
Read the bottle and if you mix it with a 50/50 mix it should be ok. Racin Randy if you know it would **** something up then why wouln't you just provide helpful info instead of responding with a smart ass comment.
There are several different configurations you can use Water Wetter in.
1. 50 Water Wetter : 50 Water
2. Water Wetter added to Coolant (see label for ratio)
3. I can't remeber the rest.
I say siphon it out with a wet/dry vac, or a pump like someone said. Good luck, and let me know how it works out for you.
DUMB A$$!!!!!!
Sorry moderaters
Originally Posted by RACIN_RANDY
I DID I SAID "READ THE CONTENCE OF THE BOTTLE" IT TELLS YOU NOT TO DO THAT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!
DUMB A$$!!!!!!
Sorry moderaters
DUMB A$$!!!!!!
Sorry moderaters
C'mon guy's its enough...
yes, vanna i'd like to buy a vowel!!
sorry i think some peaple should use commen sence and read the bottle before doing somethings, and then make your best educated guess on what will work then post your results.
and no it's not that time of the month for me yet!!!!!!!
Originally Posted by CobaltSS422
Racin Randy I think you mean CONTENTS not CONTENCE
my biggest problem!!!
becides my attittued!!!
Per the factory manual to drain the intercooler coolant you need to remove the hoses from the pump and let it drain.
So there is no plug.
Water and water wetter will probably work good as long as it stays over 32 degreee.
BlueSSupercharged
Aug 8, 2009 04:54 PM
calmb4dastorm
Forced Induction
Oct 5, 2006 05:17 PM
