View Poll Results: 2.0 LSJ ONLY: What intake do you have?
K&N Intake
24.08%
Injen Intake
45.11%
Fujita Intake
7.10%
AEM Intake
10.42%
XTC Intake
1.20%
JBP Intake
0.83%
Ebay Intake
5.90%
Rebel AutoWorx Intake
4.52%
RDFabs Intake
0.83%
Voters: 1084. You may not vote on this poll
SS/SC intakes
Old 02-14-2007, 04:46 PM
  #201
SlayeR36987's Avatar
That looks pretty good there. Im bout to order an Injen intake anyday now. Cant wait.
Old 02-14-2007, 08:36 PM
  #202
Web
Web's Avatar
The K&N with the AEM dryflow seems to have the best results....i.e. No CEL problems. Injen seems to be throwing CELs left and right.
Old 02-19-2007, 02:10 PM
  #203
AEM dryflow? Where can u get that from?
Old 02-19-2007, 02:51 PM
  #204
Johnboy12358's Avatar
You can buy them directly from AEM's website
Old 02-20-2007, 03:45 PM
  #205
Web
Web's Avatar
Here you go:
http://www.aempower.com/ViewCategory.aspx?CategoryID=93
Get an inner diameter measurement of your current filter neck or outer diameter measurement of your current intake pipe and match it to one on their list
Old 02-22-2007, 01:00 AM
  #206
jon_0_3's Avatar
so between the injen and the fujita what is the best intake in terms of hp gains, sound, cel, intstall, and price? if u know of any sound clips could u let me know.
Old 02-22-2007, 10:06 AM
  #207
Web
Web's Avatar
Injen Intake:
http://www.youtube.com/watch?v=Fh1IaHeXc5k
Haven't heard/seen any Fujita setup cobalts though..
Injen shows the most gains out of the intakes for most cars to start with. the design "should" be the same if not, extremely similar in angles and tube routing for both Injen and Fujita.
Old 02-22-2007, 12:39 PM
  #208
stweed's Avatar
does anyone know anything about the weapon-r dragon intake? i seen one on ebay and i was just wondering if it was any good.
Old 02-23-2007, 12:36 AM
  #209
Originally Posted by Web
Here you go:
Thanks man i appreciate it. Does it matter what type of filter i should get.
Old 02-23-2007, 11:42 AM
  #210
Web
Web's Avatar
You have to get the one that fits the outer diameter of your intake pipe and the length should just be no more than 5 inches long.
don't buy anything weapon R or MMW...(same company).....sh*tty products and numbers are not representative of what the car produces.
Stick to Injen/K&N/AEM.
Old 02-24-2007, 06:05 PM
  #211
G85Cobalt's Avatar
www.f5air.com there dyno sheet on a cobalt s/c is 10plus on both hp and torque..and its the only 3 inch intake on the market...i bought it and i would receommend it over the others...
Old 02-25-2007, 11:51 AM
  #212
cleanupguy's Avatar
i need some help bought a injen intake from cobalt addiction
have everything installed correctly. but problem is the car will not run well
at all. it seems to be going in limp mode. this with out driving it.
any help will be greatly app.
ps.have istalled a mass air flow sensor and runs with stock intake on
Old 02-25-2007, 05:51 PM
  #213
Web
Web's Avatar
Did you disconnect the battery for a few minutes and reconnect it? This will reset the ECU and allow it to "re-learn" the new airflow and give it the ability to adjust fuel usage.
Old 02-25-2007, 06:06 PM
  #214
1ecoss's Avatar
No one ever mentions CA CAI it is also 3" and really good quality with proven gains. Highly recommended
Old 02-25-2007, 06:08 PM
  #215
cleanupguy's Avatar
will try it thanks a lot so very upset web
same car same color sweet
Old 02-25-2007, 11:29 PM
  #216
Boost Fr33k's Avatar
Originally Posted by jeffrieckonfiyaaa
okay, after reading all of these posts and some on ss.com, no matter what intake i get, the CEL has a good chance of coming on?
because i want to either get the AEM of INJEN CAI, but dont really want to deal with the hassle of the light.
i just installed the AEM dryflow intake yesterday, perfect fit, quite simple and sick sound. plus i went from hitting 13psi to 15psi @ 32 degrees. AND NO CEL
Old 02-25-2007, 11:42 PM
  #217
campo165's Avatar
same, cept i went with injen. so CEL's here at all. as for my boost...havent watched it...i usually try not to run this car TOO hard.
Old 02-27-2007, 11:01 PM
  #218
Blue 05 SS/SC's Avatar
what kinda intake should i get for my ss/sc. also how big of exhaust should i get put on also u think 3 inch is to big
Old 02-28-2007, 10:43 AM
  #219
Web
Web's Avatar
Seems like it's up in the air between: K&N/Fujita/Injen
For the exhaust, other's please correct me if I'm wrong on this:
For S/C and N/A settings, you don't want to go much bigger than 2.5-2.75 inches inner diameter due to excess loss of pressure. In a S/C application (like yours), I would say 2.75 would be the largest I would go b/c you're still relying on the engine to produce the power and not the exhaust (just like an N/A). The S/C does help keep constant pressure in the manifold BUT, if you allow more and more exhaust gas to escape FASTER, the engine will be working harder to keep a constant pressure and be playing catch up.
Now, turbos, those you want immediate exhaust exit b/c the power of the engine is manipulated DIRECTLY by the exhaust flow itself. That's why a lot of turbo cars have electronic/mechanical dumps right after the down pipe. The faster you can get the exhaust to escape, the faster the turbine can spool thus...creating more pressure in the manifold.
For the S/C Cobalt, again, I would say no more than 2.75 inches INNER diameter for optimal performance. Anyone else got ideas?
Old 02-28-2007, 11:09 AM
  #220
cavy-to-SS's Avatar
does anybody have the jbp intake cause i have it just havent installed it yet
Old 02-28-2007, 05:55 PM
  #221
cleanupguy's Avatar
as for the exhaust i have a custom 3" catback with
a 5.25 tip for about 3 bills
i am having a fitment issue with my injen intake
does anyone know which way the mass air sensor
should point the little arrow on it mine points
down stream toward the air filter any help will
be app thanks
Old 02-28-2007, 06:10 PM
  #222
Web
Web's Avatar
be app thanks
Not 100% sure, but it should always point in the direction of the air flow.....I know exhaust parts are like that so I'm sure it would be the same for the intake. Should be pointing in the direction of the S/C.
Old 02-28-2007, 06:13 PM
  #223
Edubs's Avatar
There's an opening on the bottom end of the MAF Sensor one only one side of it. That opening should face the oncoming air...
I don't remember which way the arrow points.
Old 02-28-2007, 09:40 PM
  #224
cleanupguy's Avatar
there a little arrow on the sensor and two on the sensor
bracket which is welded on the air intake pipe.
the arrows on the stock airbox flow to the blower
but the arrows on the injen to the air fiter wtf
Old 03-01-2007, 08:12 AM
  #225
Edubs's Avatar
Who cares about arrows?
There is a hole on only one side of the sensor. The sensor can either be mounted with the hole facing the filter or the S/C. It's a functional sensor and for it to function correctly incoming air has to be directed into that hole. The hole must face towards the filter...
Quick Reply: SS/SC intakes
