SS/SC Won't Start
SS/SC Won't Start
Well I am the original owner of an '05 SS/SC. Bought it with 17 miles on it and had no problems with it in the 91,914 miles since... Until yesterday morning I went out to start up for work and just a click.
Checked the battery at Checker and Auto Zone both said it was good. Fuses all look good. Even put the battery in the wife's Jeep just to make sure it could pull a load and it started the Jeep no problem. I've run out of ideas of what could be wrong, any clues?
Checked the battery at Checker and Auto Zone both said it was good. Fuses all look good. Even put the battery in the wife's Jeep just to make sure it could pull a load and it started the Jeep no problem. I've run out of ideas of what could be wrong, any clues?Sounds like a pretty classic starter problem, so that is what I am going to guess is the problem.
Sounds to me like the starter. The bendix will pop out and that is the click you are hearing and the motor is not turning. I vote the starter pull it out take it to the auto parts store and have them test I can just about bet thats your problem.
The obvious place to look would be the starter. If you have access to a machine that does amp-draw test, see if it gives you a low amperage draw. If it does, it's 90% that you need a new starter. I doubt it's the crank sensor, cause it wouldn't even turn over. The pcm doesn't like turning the car over if it doesn't know the position of the crank.
H
The pcm doesn't like to send fuel or spark if that sensor is bad. It has no problems turning over. Just an fyi
His car just clicks when he tries to start, no crank, how is that fuel related?
I think the ignition fuse blown will cause it not to crank.
Have you tried popping the clutch?
Last edited by SCcobaltSS; Jul 28, 2010 at 03:15 AM. Reason: Automerged Doublepost
I'm sorry, I thought this was a thread for ideas to why a car won't start. If it clicks, there may be spark. It's safe to say it has air. Last part of the equation for combustion is fuel. I was having a similar issue, offered a simple thing to check. This is why I don't post tech **** anymore. Everyone is always right
Thank you to all in the community who offered suggestions as to what may be wrong with my car.
Turns out it was the starter got it fixed and it now starts no problem! Thank you again to all who responded.
OrangeCoba
Sep 25, 2015 06:06 PM
