ss/sc won't start
2.7 with 42's.....
be happy it doesn't start! this time of the year with the idc's your going to have
do you have hpt? i'd assume so, your going to have to tune the car for the new set up any way, so click the key on and see what(if any) codes pop.
also, do you hear the TB do its self check? can you hear the pump kick on?
i dunno if theres a way to check it, but make sure the bracket for the clutch engagement switch isn't broken or out of place. If the engagement switch isn't pushed by the pedal it won't let your car start. I actually had my clutch disengagment switch bracket break, and my cruise control wouldn't engage afterwards because it figure the clutch was always engaged. Try pushing as really hard down on the clutch when starting, make sure theres no carpet bunched up in the way.
Also, check and see if all of your fuses and battery connection are tight. I bumped the fuel injector relay and it came loose somehow and my car wouldn't start afterwards.
you need to relearn the theft system....
put the key in, and to the run position....let the key sit on for about 10 mintues until the security light turns off. Turn the key off, sit for 5 seconds, then turn the key on for 10 miutes until the light goes off....then repeat again for the third time....turn the key off, and it should start
well god dam son, dident you think that was some important info for us?
you need a CASE relearn done to start the car.
rite now the car is checking for matching VIN's across its parts and its not getting the "OK" thus the not starting.
if you dont have HPT you'll have to take it to a dealer.
