Stage 1 only ???
Old Jun 24, 2007 | 09:06 AM
OntarioBalt's Avatar
Canada Stage 1 only ???
Anyone only running stage 1? I searched the forums, everything is about stage 2. In a cost savings kinda way I think the HP increase in stage 1 would be ok for my needs. Can I get away with having a non-GM tech install these injectors or does it require a re-flash/calibration from GM tech to complete the install? Any info. on stage 1 would be appreciated. I guess warranty issues is why GM tech must do the install...??
Old Jun 24, 2007 | 09:22 AM
jgarciarivera's Avatar
Check this thread
https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/gm-stage-kits-faqs-read-me-first-16806/
-Stage one – Reflash and Injectors
You may have the install done from an outside shop and flashed with the author code by GM (warranty may not apply if installed by an outside shop – if part failure is found to be a direct result of how the parts were installed)
Old Jun 24, 2007 | 09:43 AM
Degashoot's Avatar
On individual basis, the Stage I will give you more HP than the Stage 1 to Stage II upgrade
The Stage II is a a much better value though....
If you can only afford Stage I, that's a good deal, but if you're planning on getting that extra 10HP (or so) that's you'll get in Stage II anytime in the future, you might as well save for the Stage II and install it all at once.
It's a much better value and you only have to pay for installation once.
DarrenGC
Dec 24, 2021 01:55 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
grampss
Sep 27, 2015 08:51 PM
