View Poll Results: Has your Stage 2 Belt Broken?
Yes, what a pos
11.63%
No, perfect condition
72.09%
Uhh-O, need to go check!
18.60%
Multiple Choice Poll. Voters: 43. You may not vote on this poll
Stage 2 Belt
Old Dec 4, 2007 | 12:06 PM
RBC's Avatar
RBC
Stage 2 Belt
Ok recently I was looking around my engine bay and found that my stage 2 belt has split in half the entire way around and is not that old. I also did a quick check and have seen that a few others are having the problem as well at the same time. So I figured I would make a poll to see how many people have and have not had a problem. So just vote and post how old the belt was when it broke or how long you have had it with no problems. Tanks
Old Dec 4, 2007 | 12:16 PM
hatrickstu's Avatar
warranty
Old Dec 4, 2007 | 12:18 PM
RBC's Avatar
RBC
So they will warranty the belt?
Old Dec 4, 2007 | 12:32 PM
JPizzle's Avatar
None of my belts have broken yet *Knocks of wood*. But my Stage WTF belt (stock on mine), works beautiful!
D4u2s0t's Avatar
they should. there's a 12 month warranty.
Old Dec 4, 2007 | 12:41 PM
RedlineBrian's Avatar
No problems here.
Old Dec 4, 2007 | 12:50 PM
RBC's Avatar
RBC
well I will have to take it to the dealer and see if they will replace it for me. I bought a new one from GM Parts Direct(cheapest place I could find) and if they replace it at the dealer I will just use it as a back up so I am never "stranded".
Originally Posted by RedlineBrian
No problems here.
How old is your belt?
Originally Posted by hatrickstu
warranty
Old Dec 4, 2007 | 12:52 PM
rallyracer's Avatar
How can you tell the difference between Belt slip and Clutch slip???
Old Dec 4, 2007 | 12:53 PM
You can usually hear belt slip. You'll know.
And i have had my belt on the car for probably a good 8-10k miles so far.
Last edited by RedlineBrian; Dec 4, 2007 at 12:53 PM. Reason: Automerged Doublepost
Old Dec 4, 2007 | 12:59 PM
Edubs's Avatar
No issues here. Over 15K total on the belt. About 5K on the Stage II pulley and over 10K on the 2.79" pulley...
Old Dec 4, 2007 | 01:40 PM
B34M3R's Avatar
With belt slip you will hear squealing, lose boost, but the engine will rev as normal.
With clutch slip your RPMs will jump without you actually accelerating, and you won't hear anything except your engine rev.
Old Dec 4, 2007 | 01:52 PM
Edubs's Avatar
It's easier to just say:
Belt slip will effect boost readings (i.e. - dropping boost levels at higher RPM's)
Clutch slip will effect tach readings (i.e. - fast RPM, slow car )
Old Dec 4, 2007 | 02:08 PM
07 SS/SC's Avatar
Mine ripped apart last night. Havent had the S2 kit on for more than 1,000 miles. My guess is the belt just wasnt put on properly and it was the mechanics fault not the belt. So I wont call it a POS, hopefully my new belt will be just fine.
Old Dec 13, 2007 | 10:41 PM
RBC's Avatar
RBC
Well the pos is just part of the yes it broke. Maybe I should of worded it different.
Old Dec 14, 2007 | 01:08 AM
rukkee's Avatar
over a year and it looks like it did when i installed it .
Old Dec 14, 2007 | 09:30 AM
Edubs's Avatar
Mine too...
Old Dec 14, 2007 | 10:15 AM
Boostin_07_SS's Avatar
my friend had his installed on the Dyno Day at Tune Time Performance over the summer.. and it broke like 30 minutes after
Old Dec 14, 2007 | 10:26 AM
They didn't have it seated on all of the pulleys correctly.
Old Dec 14, 2007 | 10:50 AM
light'bolt's Avatar
don't want to jinx myself but looks good so far...............
Old Dec 14, 2007 | 11:03 AM
Edubs's Avatar
Mine was reinstalled w/ my 2.79" pulley after they got my head back from the machine shop at TTP. Mine has been perfectly fine for the last 10K+. Who installed it on his?
Old Dec 14, 2007 | 11:13 AM
cblt12's Avatar
mine broke after about 6 months and scared the **** outta me... it lost two of the groves and there were 4-5, 6 inch pieces still attached to the belt that ripped the **** out of my hood linner.
Old Dec 14, 2007 | 08:19 PM
matt or jordan.. not to sure
Old Dec 23, 2007 | 01:31 PM
SSdan's Avatar
Just for clarification, it wasn't either one of them.....It was another guy that doesn't even work there.
Old Jan 28, 2008 | 07:53 PM
PocketRocket06's Avatar
Where can I get a new stage 2 belt? Can I order just that part through GM parts? Anyone know the part number if you can? Just put on a smaller pulley and small piece of one of the ribs on the exposed side of the belt tore, not even all the way through but I want a back up just in case it tears and its making me nervous. Any help or thoughts?
Old Jan 29, 2008 | 09:40 AM
RBC's Avatar
RBC
The part # 12597993. You can get it at Crate Engine Depot and GM Parts Direct. GM Parts Direct is a little cheaper but they both are good companies and both ship fast.
