Stage 2 Dyno Results from GM testing
My dad is a GM exec and he got this emailed to him along with other info (which I can't disclose for security reasons). These are actuall numbers as tested by GM:
As many have noted however the power does tend to go up after install when the computer has a chance to adjust to changes.
Not to mention those with upgraded pulley's etc. should notice more significant gains.
I have no info regarding what gear the pull was done, or any other info, thought I'd share the dyno sheet provided however.
Originally Posted by 05_Blue_B10WN_SS
Wonder what noob decided to rate the graph by MPH instead of engine Speed. So you minus as well subtract around 5 from all those numbers. Other then that, they are some decent numbers.
And why does it matter if it is shown in mph or rpm, there is a corrrelation between the 2 with every gear, and we all know 3rd maxes around 100 stock. I am not sure if this test even maxed out 3rd cause i don't remember what speed the car used to top 3rd at....so really those numbers could be low, and not high as you are suggesting.
Dyno results scaled by MPH and RPM will read way different.
The best results will come by using a RPM scale and the gear closest to 1:1
MPH based Dyno numbers are as accurate as a Dyno ran 1/4 mile.
As for the numbers 233HP is pathetic for the Stage 2 others have allready beat that number with there own Stage 2 dyno results not to ment ion in fourth gear.
True, I agree completely and I look at it this way. Their base was 193.66!! We all know that the ss/sc dyno's well over that stock. So Im looking at their gain of 40 HP to their baseline to their stage 2, and adding that to the around 215 that these cars actually make and a realistic logical HP should be around 255.
I'd say 255 is about where it's at given that assumption, do you guys agree?
Originally Posted by CleanNFun
Besides the numbers I have to say awesome looking car!!! Those headlights are sick
, I didn't even think it was a cobalt at first
the cobalt dynos around 193 on a mustang dyno.
Actually, MPH is a linear function of RPM. It is nothing more than changing the labels on the x-axis.
I've had my car dynoed on a dynojet, and my tuner then chose what variables to show on what axis. My max HP was the same no matter what variables were chosen.
An exhaust and manifold upgrade give a 33 HP increase!?!?!?! Are these the GMPP extrude honed manifold and GMPP cat-back? I didn't think these would afford THAT MANY extra horses!?
Also, what is wrong with the power band on the stock run between 83 and 93 MPH?? I thought our HP curves should be flatter than that throughout the revs.
What do you guys/gals think?
The exhaust upgrades are 7 HP. Stage 2 is 33HP. At least that is the way it looks to me.
Im sorry but there is no way it only makes 223 wheel power.....I let my friend with a MODDED evo drive it and then did a quick roll with him.....and it pretty damn close, if he's beating me it's not by a whole lot. He's running a tubular manifold full turbo-back with 02housing, upper and lower intercooler pipes with an intake and a boost controller....I would go with that one guys assumption of around 250 wheel OR more. I hopefully can dyno mine soon to see what this thing is making.....but it feels DAMN FAST.
Just to add the blue graph labeled dynorunex stands for exhaust and manifold dyno, the other is baseline stock, the other is stage 2
ummmm no way the exhaust manifold and an exhaust gained 31whp, those are ricer #'s
that would be about 40 crank hp
