stage 2 first then 65lbs injectors?
i have a stage 2 kit and a 2.8 pulley sitting on my floor. i was thinking about just getting ZZP Interchangeable Pulley System with a 2.6 pulley and ZZP Pulley Puller and ZZP Adjustable Tensioner and SIEMENS 60lb injectors, and putting it on myself, but then i remember the stage 2 requires a reflash... so should i just get the stage 2 upgrade with reflash first? or is someone with hptuners able to eliminate that problem?
wow i'm an idiot. o wow. you are right lol i feel stupid. imma put that **** up on ebay. well thanks for making me think straight
eh i havent listed the springs rotors and brake pads o_O
the zzp pulley system with a 2.6" pulley doesnt require me to grind anything does it?
Last edited by onlyultimate; Feb 17, 2007 at 10:51 PM. Reason: Automerged Doublepost
zzp rents the tool to machine the snout I'd do the 2.6 and 60's. You will need a tune to run the 60 lb injectors. You could also get one of the intense kits and they can do the tune for you also.
it says on the website
"ZZPerformance pulleys do not require snout machining. By developing Ecotech specific pulleys we run all the way down to 2.6" w/o snout machining."
http://www.zzperformance.com/cobalt_...=446&catid=142
Just stick wit a 2.7" or 2.8" pulley. When you go below that you get too much heat and its not efficient at all. It will be passable if you get cooling, but your still overspinnin the blower. Think about reliability a lil unless its purely your racin car.
Definately....I installed one and the bottom of the snout was rubbing. We started it up and the pulley froze and the belt continued to move. We were like WTF....
