Stage 2 injector?
whats the parts Number on the side of? i dont think i got stage 2 injectors because i saw a pic of them and mine dont looks like the ones i have seen.(i bought the kit used off ebay)just to let you know.
Can anyone get me a good picture of a stage 2 injector?
well maybe you should post the pic of your injectors it would be easier!
GM stage injectors have black connectors. the stock injectors have green connectors. thats ones of the easiest ways to tell.
ok ill try to get one up.
Ok i got three pictures here is a close up of one of the injectors. https://www.cobaltss.net/gallery/fil..._002_thumb.jpg what are these round things with o-rings that go on the bottom of the injectors https://www.cobaltss.net/gallery/fil..._003_thumb.jpg And heres a pis with the harness and all the injectors https://www.cobaltss.net/gallery/fil..._001_thumb.jpg Now are these stage 2 injectors? if not what are they? The number on the side of them is 01D030B. If that helps at all Thanks. |
here is a stage 2 kit someone is selling on here you can compare that way I dont think those are but I am not sure.
http://cgi.ebay.com/ebaymotors/Cobal...Q5fAccessories here is some more info Part Numbers are - Stage 1 – 17801947 - Stage 2 – 17803229 - Stage 1-2 – 17803230 belt PN# 12597993 Kit includes: 1-12597994 pulley 1-12597993 belt 1-12597995 Injector kit 4-12597996 Injector (single service number) 1-19158223 Wrench 1-19158224 Wrench 1-12599777 Hub 4-19157352 Bolts 1-12602431 Label 1-12597997 Instructions |
yea my injectors look differant
They may be 60#s lol I really dont know but check the numbers I posted on them if there are any!
Originally Posted by *boostinss*
(Post 4245447)
Ok i got three pictures here is a close up of one of the injectors. https://www.cobaltss.net/gallery/fil..._002_thumb.jpg what are these round things with o-rings that go on the bottom of the injectors https://www.cobaltss.net/gallery/fil..._003_thumb.jpg And heres a pis with the harness and all the injectors https://www.cobaltss.net/gallery/fil..._001_thumb.jpg Now are these stage 2 injectors? if not what are they? The number on the side of them is 01D030B. If that helps at all Thanks. they look like lucas 42 lb/hr injectors. zzp sells them along with other vendors. |
That could be! I dont think they are GM injectors!
Originally Posted by KillerBee
(Post 4245689)
(Post 4245699)
http://www.zzperformance.com/cobalt_...=481&catid=174 ^ try that link. those are what the lucas 42# injectors look like that zzp sells. |
does def look like lucas 42's...wont matter same size, just as long as the harness u got clips in you should be fine with the stgII tune, if you having custom tuning you shoudl still be ok with those, same size as the stgII, but they def look like lucas 42lbs...
yeah i think i might have gotten lucas 42# injectors. they have the same little blue band around the top. but the only thing is the number on the side of mine are differant then the one on the side of the one from zzperformance. and is this the harness from zzp also? wheres zoomer when i need him. lol im guess im i got a good deal from this stage 2 i bought off ebay. lol Will this work good with the zzp tune that im saving up for? im just going to be running the gm stage 2 pulley?
well gm or lucas, injectors are injectors, if they work they work ;)
Originally Posted by Jn2
(Post 4245947)
A quick Google search with the number you gave shows up as Lucas.
Part Number 01D030B (Lucas old 5208009, Lucas New 621031, Delphi old D3181AA) |
so these are definitly lucas 42# injectors
(Post 4247686)
