Stage 2 injector?
Stage 2 injector?
whats the parts Number on the side of? i dont think i got stage 2 injectors because i saw a pic of them and mine dont looks like the ones i have seen.(i bought the kit used off ebay)just to let you know.
ok ill try to get one up.
Ok i got three pictures
here is a close up of one of the injectors.
what are these round things with o-rings that go on the bottom of the injectors
And heres a pis with the harness and all the injectors
Now are these stage 2 injectors? if not what are they? The number on the side of them is 01D030B. If that helps at all Thanks.
Last edited by *boostinss*; Aug 25, 2009 at 12:11 PM. Reason: Automerged Doublepost
here is a stage 2 kit someone is selling on here you can compare that way I dont think those are but I am not sure.
http://cgi.ebay.com/ebaymotors/Cobal...Q5fAccessories
here is some more info
Part Numbers are
- Stage 1 – 17801947
- Stage 2 – 17803229
- Stage 1-2 – 17803230
belt PN# 12597993
Kit includes:
1-12597994 pulley
1-12597993 belt
1-12597995 Injector kit
4-12597996 Injector (single service number)
1-19158223 Wrench
1-19158224 Wrench
1-12599777 Hub
4-19157352 Bolts
1-12602431 Label
1-12597997 Instructions
Part Numbers are
belt PN# 12597993
Kit includes:
1-12597994 pulley
1-12597993 belt
1-19158223 Wrench
1-19158224 Wrench
1-12599777 Hub
4-19157352 Bolts
1-12602431 Label
they look like lucas 42 lb/hr injectors. zzp sells them along with other vendors.
yeah they are deff. not the GM Stage kit injectors.
http://www.zzperformance.com/cobalt_...=481&catid=174
^ try that link. those are what the lucas 42# injectors look like that zzp sells.
Last edited by Staged07SS; Aug 25, 2009 at 12:30 PM. Reason: Automerged Doublepost
does def look like lucas 42's...wont matter same size, just as long as the harness u got clips in you should be fine with the stgII tune, if you having custom tuning you shoudl still be ok with those, same size as the stgII, but they def look like lucas 42lbs...
yeah i think i might have gotten lucas 42# injectors. they have the same little blue band around the top. but the only thing is the number on the side of mine are differant then the one on the side of the one from zzperformance. and is this the harness from zzp also? wheres zoomer when i need him. lol im guess im i got a good deal from this stage 2 i bought off ebay. lol Will this work good with the zzp tune that im saving up for? im just going to be running the gm stage 2 pulley?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
