Stage 2 injector?
Old Aug 24, 2009 | 11:15 PM
*boostinss*'s Avatar
Stage 2 injector?
whats the parts Number on the side of? i dont think i got stage 2 injectors because i saw a pic of them and mine dont looks like the ones i have seen.(i bought the kit used off ebay)just to let you know.
Old Aug 25, 2009 | 10:53 AM
Can anyone get me a good picture of a stage 2 injector?
Old Aug 25, 2009 | 10:57 AM
KillerBee's Avatar
well maybe you should post the pic of your injectors it would be easier!
Old Aug 25, 2009 | 11:21 AM
Staged07SS's Avatar
Administrator
Administrator
GM stage injectors have black connectors. the stock injectors have green connectors. thats ones of the easiest ways to tell.
Old Aug 25, 2009 | 12:11 PM
ok ill try to get one up.
Ok i got three pictures
here is a close up of one of the injectors.
what are these round things with o-rings that go on the bottom of the injectors
And heres a pis with the harness and all the injectors
Now are these stage 2 injectors? if not what are they? The number on the side of them is 01D030B. If that helps at all Thanks.
Last edited by *boostinss*; Aug 25, 2009 at 12:11 PM. Reason: Automerged Doublepost
Old Aug 25, 2009 | 12:16 PM
KillerBee's Avatar
here is a stage 2 kit someone is selling on here you can compare that way I dont think those are but I am not sure.
http://cgi.ebay.com/ebaymotors/Cobal...Q5fAccessories
here is some more info
Part Numbers are
- Stage 1 – 17801947
- Stage 2 – 17803229
- Stage 1-2 – 17803230
belt PN# 12597993
Kit includes:
1-12597994 pulley
1-12597993 belt
1-12597995 Injector kit
4-12597996 Injector (single service number)
1-19158223 Wrench
1-19158224 Wrench
1-12599777 Hub
4-19157352 Bolts
1-12602431 Label
1-12597997 Instructions
Old Aug 25, 2009 | 12:20 PM
yea my injectors look differant
Old Aug 25, 2009 | 12:22 PM
KillerBee's Avatar
They may be 60#s lol I really dont know but check the numbers I posted on them if there are any!
Staged07SS's Avatar
Administrator
Administrator
they look like lucas 42 lb/hr injectors. zzp sells them along with other vendors.
Old Aug 25, 2009 | 12:23 PM
KillerBee's Avatar
That could be! I dont think they are GM injectors!
Old Aug 25, 2009 | 12:29 PM
Staged07SS's Avatar
Administrator
Administrator
60 lb/hr injetors are usually skinny/longer. i really believe they are the lucas 42 lb/hr injectors.
yeah they are deff. not the GM Stage kit injectors.
http://www.zzperformance.com/cobalt_...=481&catid=174
^ try that link. those are what the lucas 42# injectors look like that zzp sells.
Last edited by Staged07SS; Aug 25, 2009 at 12:30 PM. Reason: Automerged Doublepost
Old Aug 25, 2009 | 01:07 PM
Jn2's Avatar
Jn2
does def look like lucas 42's...wont matter same size, just as long as the harness u got clips in you should be fine with the stgII tune, if you having custom tuning you shoudl still be ok with those, same size as the stgII, but they def look like lucas 42lbs...
Old Aug 25, 2009 | 01:20 PM
yeah i think i might have gotten lucas 42# injectors. they have the same little blue band around the top. but the only thing is the number on the side of mine are differant then the one on the side of the one from zzperformance. and is this the harness from zzp also? wheres zoomer when i need him. lol im guess im i got a good deal from this stage 2 i bought off ebay. lol Will this work good with the zzp tune that im saving up for? im just going to be running the gm stage 2 pulley?
Old Aug 25, 2009 | 01:22 PM
Jn2's Avatar
Jn2
well gm or lucas, injectors are injectors, if they work they work
Old Aug 25, 2009 | 01:23 PM
Staged07SS's Avatar
Administrator
Administrator
x2 !!
Old Aug 25, 2009 | 10:22 PM
Gene Culley's Avatar
Talking
A quick Google search with the number you gave shows up as Lucas.
Part Number 01D030B (Lucas old 5208009, Lucas New 621031, Delphi old D3181AA)
Old Aug 25, 2009 | 10:30 PM
so these are definitly lucas 42# injectors
Old Aug 26, 2009 | 07:10 AM
Staged07SS's Avatar
Administrator
Administrator
that's what i figured
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
yellow dragon
Sep 28, 2015 09:49 PM
