Stage 2 and my clutch is slipping like a bat out of hell!!!!!
Ok so today im racing my buddy basically same mods but were just ******* around you know....well it wasnt really a launch it was from a coast in 1st to 6800 rpm;s and 2nd well my damn clutch was slipping.... and its been doing this for a while but i never really paid attention to it i guess because i dont launch this car alot at all....
I baby this car, i race every now and then and if i do its from rolls.....not digs....Now, is there anyway that this clutch could be warrantied?? I mean my dealer is pretty cool about mods and everything else and i also bought my car from there so i mean they are pretty leanant....So if anyone could give me the jist of what i have to say and do to get it covered then let me know
ATTENTION READ THIS POST BEFORE GOING TO THE DEALERSHIP
You are experiencing a problem that tons of stage 2 cobalt owners experience. This clutch slipping is caused by what we call "glazing the clutch". This results from repeatedly engaging a performance clutch at lower rpms.
I had the exact same problem and heres how I (and many other stage 2 owners) fixed it.
From now on, NEVER shift your car before 3000 rpm. You won't save gas by shifting early than that, i promise. If you do this consistently in every gear from now on, i guarantee your clutch will work like a champ in about a week.
For some reason, these clutches hate being engaged at lower rpms and will get a glaze over them which in turn makes them less likely to grip, especially in first gear.
because you go from a good launch from 1st gear and then 2nd gear there is nothing there but when you press the throttle of increasing rpms but your not going newhere like your in gear, but all it does is act like your reving up your car.....Pisses me off...Its been doing this way before i had stage 2 on my car
mine does it too every once in a while. i kinda stopped doing it for a while and it seems better. i'd say take it easy on the quick shifts. if you actually wait like a quarter of a second longer you'll find it wont slip
hasnt happened on mine yet but only about 2600 miles on my car.
I had it happen to me once; it's when you try to drive the car like a slip clutch. You just can't do it, you have to apply the clutch 100% (you can still do this smoothly) before or just as you go WOT not after. After it happened to me once it hasn't happened again. It is driver error if it happens.
This is a common thing for our cars. It sattes in the build book when you put stage 2 on that because of the increase hp the clutch will need to be replaced.
Our clutches are the same one that they put into the regular cobalts that only have 150hp.So don't be suprised just save up and buy a updgraded Clutch and flywheel.
my clutch started slipping shortly after getting my stage 2 installed. my dealer called gm tech assist about it and we were told with stage 2 an upgraded clutch is recommended.
before anyone calls b.s. i was sitting right there listening to the call. I went and bought a spec stage 2+ clutch. i paid it for but the dealer was nice enough to install it for nothing. now its nothing but tiring burning and chirping when i grab gears. i also can shift at 2000rpm and not "glaze" the clutch.
just face it the stock clutch is junk. save yourself the trouble and aggravation and get a performance clutch. Then you can drive the car how it should be driven.
It's easier to practice this when shifting over 3k, hence why it's recommended, but once you get the hang of it, you can shift where ever you want and it won't hurt a thing.
It's not about where you shift, it's how. The revs take a long time to drop in the car when you let off the gas, and in normal driving, you have to take your time shifting. Clutch in, shift, and wait for the rpm to be where it should be before you let go. When you do let go, do it quickly. Disengaging the clutch too soon or too slowly causes it to slip a little with every shift, even if you can't feel it, and that's what causes the glaze and premature wear.
Also about the gas mileage at those rpms, its insignificant. With my mods in my sig and a heavy foot, i get 27.5-30 mpg.
QFT... worked for me.
Your mods wouldn't hurt gas mileage. Well the stage 2 with the increased boost and a heavy foot would, but for regular driving it shouldn't. I actually got 1mpg better with my stage 2 then I was getting before and it's been a little more "spirited". Sure the difference between that 1-2 seconds from 2500rpm to 3000rpm before a shift isn't gonna make a difference, but if I'm cruising for 20 minutes at 60mph in 4th 2900rpm, you can damn well count on the gas mileage suffering if I didn't shift into 5th and dropping 600rpms.
Alot of people are thinking it. but no one wants to say it.
Its not the clutch.
there may be a few clutches out there that are sincerely faulty, and need to be replaced.
but the fact is...most of the "omg my clutch is slipping" cases. are caused by a driver who is either new to stick, or coming from stick cars that didnt have enough power to burn their clutch anyway.
Its a wear and tear item. Im not trying to be a dick.
but i ask you to answer this question.
Why is it the drivers with alot of stick experience. have no problems with their clutches?
My clutch has slipped once.
and it was 100% because of the way i moved my feet at the time.
I knew it....corrected it....and havent done it since.
Nor has my clutch slipped since.....
Sorry man. This probably sounds like me being a *****....but this is part of learning to drive. GM probably isnt gonna pay for it.
Its not the clutch.
