stage 2 SC Hub and pulley?
Old May 21, 2007 | 01:06 AM
07 SS/SC's Avatar
Can I buy the GMPP SC hub and stage 2 pulley alone? Or can I only get it in the stage 2 kit? The reason I am asking is to see if there is a cheeper way to put togeather a GMPP stage 2 package. For example, buying stage one and getting the snout and pulley seperatly.
Thanks, Mike
Old May 21, 2007 | 01:11 AM
beamSS's Avatar
maybe you mean sc hub. why?
Old May 21, 2007 | 01:15 AM
07 SS/SC's Avatar
Yes, I ment hub ( I dont know what I was thinking when I typed snout) The reason being is I work at a GM dealership and I can get things for cost. If I buy stage one and can get the hub and pulley alone, I will save some money and have a complete GMPP stage 2 kit. I am just looking to see if I can get S2 cheeper. I am not really worried about how much it will cost, just seeing if I can get a better deal.
Mike
Old May 21, 2007 | 01:16 AM
Bika's Avatar
Fail Less.
no. you have to buy the kit, unless you buy a used stage 2 hub and pulley from someone.
i tried the stage 1 and then bought a stg 2 pulley. it is NOT the same ecu recalibration. i was severely lean with the stg 1 tune. got myself a stage 2 ecu recalibration and it made a world of difference in performance and it dumps way more fuel because of a richer commanded A/F ratio.
Old May 21, 2007 | 01:22 AM
07 SS/SC's Avatar
See I was told yesterday on this site that stage one and two have the same PCM tuning. Anyone else have some insite on this?
Mike
Old May 21, 2007 | 01:35 AM
blownssdel's Avatar
99.9 percent sure the tunes are the same
Old May 21, 2007 | 01:48 AM
Doc's Avatar
Doc
much cheaper to piece it together.....
Old May 21, 2007 | 01:54 AM
07 SS/SC's Avatar
So I can piece it togeather and keep it all GMPP and under warrenty?? I was hoping I could just get the stage one kit and buy the hub and pulley alone making it a stage 2 kit but for far less money.
Old May 21, 2007 | 08:46 AM
ralliartist's Avatar
just get a modular pulley kit from njhk or something like that. I'm sure he will chime in soon. $90 bucks will get you whatever pulley size you want and a hub. Then you can get the gm stage 1 kit so you have injectors and a tune. Cheaper than STG 2!
Old May 21, 2007 | 10:40 AM
Bika's Avatar
Fail Less.
njhk doesnt sell pulleys. different guy you're thinking of is nate (cant remember screen name) but he custom makes pulleys and hubs.
i just tried doing that pieced together kit with stage 1 and the pulley. it works but the car runs lean. once i got the correct tune i run way rich now and the car pulls harder and sounds meaner. stage 1 tune does not command the same A/F ratio as the stage 2 tune. you might get away with it for a while but you arent doing your engine any favors. don't cheap out on the important stuff.
Old May 21, 2007 | 11:11 AM
07 SS/SC's Avatar
Thanks for all the suggestions guys! I dont want to go with a pulley set up if its not GMPP, I really want to keep my warrenty. I guess I will have to look into the stage one and two tunes alittle more before I buy one.
Thanks guys!
Old May 21, 2007 | 04:48 PM
well, if you want to keep your warranty, then your best bet is just getting stage 2. You aren't going to find that hub anywhere. good luck.
Old May 22, 2007 | 01:23 PM
Bika's Avatar
Fail Less.
stage 1 with a smaller pulley is not warrantied. dont listen to those morons who tell you its the same tune. i speak from experience that it's a different part number and it runs a completely different AFR.
Old May 22, 2007 | 01:52 PM
07 SS/SC's Avatar
Thanks for the input Bika, it looks like I will be going for just stage 2 when I am ready.
Thanks, Mike
Old May 22, 2007 | 08:52 PM
LightngBalt's Avatar
Although I agree with you, that you would probably have warranty problems with stage 1 and an aftermarket pulley.
According to the Stage kit sticky on this site, there is only ONE GM Stage tune. LINK
Take note of the second post, first line after the picture.
To the original poster, if you look around Ebay, here and a couple other sites, you may be able to come across a GM hub and pulley. I found a good deal on the hub, with stage 2 and 3 pulleys, on Ebay.
Old May 22, 2007 | 09:57 PM
Bika's Avatar
Fail Less.
yeah i read that sticky, thats why i tried it. i also bought the gm hub and pulley used in the classifieds here. but i know what my a/f was when i ran that set up and it wasnt pretty.
Old May 22, 2007 | 11:33 PM
07 SS/SC's Avatar
I too had read that sticky but I have heard both sides of the story. Some saying they are the same and others saying the A/F ratio is different between the two. Thanks for the heads up about ebay I will have to check that out! I think I am going to just get stage two when I am ready and not chance having a messed up A/F ratio.
Mike
Old May 22, 2007 | 11:46 PM
ggarcia86's Avatar
you can buy my stage 2 pulley, or my extra 2.8" pulley? but i'm keeping the hub! hah
Old May 23, 2007 | 12:57 AM
Doc's Avatar
Doc
I honestly wonder where some of the information comes from these days.
Actually, I wonder why it gets convoluted so badly. It's a miracle some people can even use a computer.
Old May 23, 2007 | 02:02 AM
07 SS/SC's Avatar
Doc, I have got to agree with you on that one. I have been on many car forums and every time I join a new one there is one (usually more) thing/s that half the people say and it is completely wrong then the other half says something and it is 100% correct. The hard part when your a noob (like I am on this site) is figuring out which is the correct one.
Mike
Old May 23, 2007 | 02:09 AM
ItalianJoe1's Avatar
Do you have logs of before and after? or any other proof?
Old May 23, 2007 | 01:16 PM
Bika's Avatar
Fail Less.
i REALLY wish i had access to a dyno or atleast some hpt, but i dont have any dyno sheets or hpt logs to post. just a set of fucked up spark plugs (white and rainbow colored means cylinder temps too hot due to lack of fuel usually) and i could take some pictures of the car puffing some black smoke from the exhaust where as a non-stage2 calibration vehicle will not.
let me flip that question.... does anyone have data or dyno sheets that give evidence to support the theory of having one tune for both stage kits?
Old May 23, 2007 | 11:23 PM
Doc's Avatar
Doc
You're serious ....I have multiple hpt files that support that argument. The only differences are the years. The stage 1 and stage 2 tune is identical. GM's literature even states that. The difference is the smaller pulley for stage 2.
Old May 23, 2007 | 11:39 PM
gobalt's Avatar
calibration numbers from stage 1 to stage 2 are different, sets up the spark advance way different, it will work but you wont get the most out of it.
Old May 25, 2007 | 10:17 PM
Bika's Avatar
Fail Less.
if GM's literature stated that the stage 1 and 2 ecu flash is the same, why would they require it when upgrading from 1 to 2? it doesnt add up.
