Stage 2 with stage 3 pulley
stage 2 is 3.06 stage 3 2.99
i have a 3 inch pulley runs good no problems i stayed away from the 2.9 due to maxing out injectors
stage 2 to stage 3 will just bring the tourqe out a tad bit earlier probably...people that had it said they've felt a slight difference thats why i got a 3 inch 50 buck from smoothflow pretty much stage three
Yah I'm 3.0 on stage 2 also... need to create a name for that lol. Stage 2.5 maybe
I felt an improvement, and I don't say that often.... I didn't say it when I got my catback or intake.. but this 3.0, defintitely yes.
Do a 2.9 if your gonna drop from a stage 2 pulley... The difference between stage 2 and 3 is very minimal as stated....
You might wanna think about some traction and cooling mods too if you havent done them yet... They will bring out whats already in the car to the fullest
don't do a 2.9 unles you have someway to check if you r maxing out your injectors...some people do some don't.. i wouldn't recomend i ttho unless your going with 60's
Meth is by far the best cooling mod but you need to get t00ned for it
after my warrenty runs out.
i am gonna get wisco pistons, eagle rods, arp head studs, port and polished head, titianum valves and stiffer springs, stg2 comp cams, 2.7 inch pulley and 60 lb injectors, and a professional customer tune.
i know some of this sounds bad but i never built a motor before so this stuff just sounds good to me to do
I was like that waiting for my warranty and then I said forget it and started putting whatever I want on the car. I might build it up over the winter if I am around here.
get cooling mods if u can. Im having major IAT2 issues with a 3.00 and trying to stay off WOT pulls. Especially in 100 degree weather where it heats up from 130-180ish from 0 - 100 mph under WOT.
