Stage 2 Upgrade 3.1" or 3.0"?
I know there are a lot of threads about the stage kits but I have yet to get a definite answer on this. I have a stock cobalt aside from a stage 2 clutch and a zzp 3" CAI, is it safe to run a 3.0" pulley with 42# injectors and NO cooling mods? Or should I just go with the 3.1"? I plan on replacing my exhaust soon as well but I don't want to put money into cooling mods right now. I just don't need anything breaking. If any of you guys could help me Id appreciate it.
do you wanna put money into fixing a blown motor?
ha so youre saying i should go with the 3.1?
You could really go as far as 2.8 and 60's with no supporting mods, but you're IAT2's will be pretty high after 1 pull.
Its fine to run a 3.0 with no extra cooling mods.
However, it is not fine or safe to toss in a 3.0 and injectors and run it. There is this thing, its called tuning for it..... If your stock then stage up the right way. Option B, FMHE, Dual pass, 3.0 or 2.9, 42's, wideband, and a custom tune. |
(Post 7072165)
(Post 7072336)
(Post 7072384)
There is this thing, its called tuning for it..... Option B, FMHE, Dual pass,. yes tune is needed COOLING MODS ARE NOT The only one's worth a dam is the option b and a extra h.e. or a griffen or similar capacity is where you get better temp control |
I ran my 2.9 on gm stage 2 for a year before I put my option b, h/e and dual pass on. Just don't do pull after pull after pull and you should be fine
Alright I am leaning towards the 3.0 now and just not gonna beat on it too bad until I get the endplate and option b. My question now is 42# injectors okay to run on that?
Yes, 42# will handle 3.0 just fine. 2.9 and lower you're gonna wanna upgrade.
Alright thanks a lot you guys
(Post 7072568)
(Post 7072681)
I was told by a reputable tuner on here that 42's would be fine for up to a 2.8"
I maxed out 42s at around 5500 rpms on a 2.9 back in the day.
Originally Posted by mrbelvedere
(Post 7072402)
COOLING MODS ARE FOR RECOVEREY
yes tune is needed COOLING MODS ARE NOT The only one's worth a dam is the option b and a extra h.e. or a griffen or similar capacity is where you get better temp control When will people learn!? |
