stage 3 blew internals
Old Jul 18, 2007 | 02:29 PM
MadboostSS's Avatar
1 of my friends put a stage 3 on his cobalt and somewhere around 1k miles he blew his internals. how do you blow internals on a 2.7 pulley? jw because i have a 2.7 and i dont want that to happen to me.
Old Jul 18, 2007 | 02:31 PM
fastls's Avatar
...... cooling mods and the right tune
blackngold20's Avatar
did he put these mods on before or after he broke in the car?
Old Jul 18, 2007 | 02:34 PM
FNFAST's Avatar
well from the fact it is a 2.7...we know it isn't GM STAGE 3.
Old Jul 18, 2007 | 02:35 PM
BriantheLion26's Avatar
While we are on this topic, how is your S3 holding up? Have any track times on it yet?
Psykostevo's Avatar
Easy, he needed to learn how to drive, and probably had no idea what heat soak or knock is.
You can blow your car in 3 hard back to back pulls the first day you install those kits. It sucks for your friend, but it is probably 90% his fault.
Old Jul 18, 2007 | 02:38 PM
Area47's Avatar
Rent me! per hour
user error.
a 2.7 on 42's is not a good idea with our fuel systems.
Old Jul 18, 2007 | 02:39 PM
tum_tum's Avatar
a 2.7 with 42 lb injectors your d/c was probly off the charts and a injector went static and injector static=boom
Old Jul 18, 2007 | 02:40 PM
RaineMan's Avatar
Lemme guess... INTENSE Stage 3?? their tunes are reported to be canned crap. He's not the first...
Old Jul 18, 2007 | 02:42 PM
FNFAST's Avatar
It is holding up great man. on my 5th bottle of juice and 20 gallons of 109 octane.
I went a couple times...got a 12.0 slip is on here somewhere.
Old Jul 18, 2007 | 02:43 PM
alleycat58's Avatar
Exactly.
What did his wideband say as far as a/f?
What was he using to monitor IAT2s and knock? If there was something off and he was properly monitoring what the car was doing, he would have known what it was and/or could have prevented it.
Yeah, I thought it'd been pretty well established around here that anything smaller than about a 3" pulley + 42#ers = engine death
Old Jul 18, 2007 | 02:46 PM
FNFAST's Avatar
I'm not saying right or wrong..but I am running nitrous with my 42's (2000 miles now, 5 bottles later, just fine) and my brother has a CA 2.79 on his GM stage 2 with about 6 thousand miles on it and his car is running AOK.
WIERD
BallsoutBalt's Avatar
Uh, What everyone else said...
2.7 Pulley+ 42's = DANGER, switch to a 2.9
Back to back racing = DANGER, Allow for cool down time
Anything but a custom tune = DANGER, It really is worth the extra $
Trying to have sex with your Wife's sister = DANGER!!!!
Old Jul 18, 2007 | 02:48 PM
FNFAST's Avatar
Jmc007's Avatar
Sometime just the fact that the car is currently doing ok doesn't mean that it's within safe limits ...
FNFAST's Avatar
She always gets so bent out of shape when she finds out about that one
Old Jul 18, 2007 | 02:49 PM
tum_tum's Avatar
no matter what a 2.7 with 42's its only a matter of time before your injectors go static....or you blow a piston or 4 with the n02
Old Jul 18, 2007 | 02:50 PM
FNFAST's Avatar
I agree...excpet that I have a warranty so I could care less.
and I think that 6K miles...is not "currently"...pretty sure that after 6K and it is still running GREAT! that it should be ok.
?? not arguing...just saying.
Area47's Avatar
Rent me! per hour
Originally Posted by alleycat58
Exactly.
egt is more important than a/f at a point.
im runnin a 2.8 on 42's, and have lower IDC's then people runnin 3.0. it's all in how you go about doing it
Old Jul 18, 2007 | 02:51 PM
FNFAST's Avatar
trust me when I say that he beats the **** out of that thing and it runs like a top
tum_tum's Avatar
what warranty..you are running n02 voided warranty
Old Jul 18, 2007 | 02:52 PM
1stbluSS's Avatar
Just because FNFAST's motor hasn't blown yet doesn't mean yours won't.
Take the neccesary precautions. Here is the thing. If you introduce more air you have to introduce more fuel. If you are introducing more of those items you are also introducing more heat. For every 10* cooler your engine will increase HP efficiency by 1%. For every pound of boost your engine increases HP 7% and I beleive 5 degree's of heat. You cannot have one without the other it is that simple.
More Air into engine needs more fuel , and a way to cool the air that was introduced. Also to me having a 2.7 without an aftermarket exhaust is crazy that is a lot back pressure you are building. PSI = pressure
So when any of you want to get a smaller pulley other than something modest like mine.
Say 2.9 now you need higher flow injectors, another heat exchanger wouldn't hurt, and an exhaust.
Otherwise you will eventually run into trouble.
I repeated myself in 4 different ways but you kids just don't get it.
N8s07SS's Avatar
Judging by the fact that you think you have too many "modes" done to your car, I'm going to go out on a limb and agree with everyone else who thinks it's user error.
Old Jul 18, 2007 | 02:53 PM
tum_tum's Avatar
stage3 voids your warranty minus the n02
cybcow's Avatar
Tune!
