STG II to 2.8 Question
Old Mar 14, 2008 | 10:16 AM
Netsyphen's Avatar
Since the Stage II tune tends to run rich, would I be ok dropping it to a 2.8" pulley without a tune and the Stage II injectors. I have the pulley, but I don't have the money right now for the 60lbs and a new tune.
Old Mar 14, 2008 | 10:19 AM
SJSchafer's Avatar
Search button is your friend. This topic has been discussed ad nasium. In short... no.
Old Mar 14, 2008 | 10:21 AM
LopsidedJester's Avatar
i'm sure you could live with it for a while, there are plenty of guys on 2.8" pullies and stage II injectors (42lb injectors) and tune. Most people would recommend you ditch it and get a 2.9" to be safe.
Old Mar 14, 2008 | 10:24 AM
invisible's Avatar
I have had mine like that for 1 1/2 years and its been fine.
Old Mar 15, 2008 | 09:23 AM
fst07ss's Avatar
I have the stage 2 with 2.8 pulley for almost a year now, no problems, car runs strong!
Old Mar 15, 2008 | 09:24 AM
anthonyS88's Avatar
just run the 2.9, its safer. unless you have HPT so you can see what you IDC's are
Old Mar 15, 2008 | 10:35 AM
CREW54's Avatar
I debated going to the 2.8, but after researching on here, I decided the 2.9 was the wiser choice; being on the safe side of the envelope.
Old Mar 15, 2008 | 11:08 AM
rukkee's Avatar
Your running meth thou right?
Have you logged your IDC? I'd like to see what they are in the higher RPM ranges. My guess is pissed.
Old Mar 15, 2008 | 11:14 AM
Darkmanx's Avatar
2.85 And 2.9 make your damn idc almost the same ****, ive logged on both and the **** dont change boost is the same iat2 is the same idc is the same no damn difference. I dont know about a true 2.8 though
Old Mar 15, 2008 | 11:22 AM
An00b's Avatar
changing your pully doesnt change your AFR.
the car will still try and run rich even with the 2.8 on, which is why the injectors have fits.
S2 running rich doesnt mean its safe to just throw a smaller pully on.
Old Mar 15, 2008 | 11:46 AM
lsjwannabe's Avatar
^^ bingo
Old Mar 15, 2008 | 11:54 AM
rukkee's Avatar
Wow your new here and get it. There are some that have been here forever that haven't figured that out yet lol.
So what are they ? Are you running a stage tune?
Old Mar 15, 2008 | 01:04 PM
RedEcotecSS's Avatar
wait for the 60#ers man. better safe than sorry, right?
Old Mar 15, 2008 | 01:10 PM
CobaltSS 16's Avatar
I would go with the 2.9 and still get tuned.
Old Mar 15, 2008 | 07:47 PM
jimmyfoxx's Avatar
i here some people getting a stage 1 and dropping a 2.9 in. is gm s1 and s2 the same tune? isn;t the only difference is that gm s2 just has the smaller pulley and belt?
Old Mar 15, 2008 | 08:05 PM
07 SS/SC's Avatar
Bingo x384394839
Old Mar 16, 2008 | 01:52 PM
Littlegoose's Avatar
and bingo x230493453
Same tune, just smaller pulley/belt. If you plan on downgrading pulleys, no real reason for s2. Just buy s1 and the pulley and belt later when you decide to go smaller.
And as people are saying, smaller pulley doesn't increase AFR. AFR attempts to stay the same as it is a direct function of your tune. It simply says, instead of getting X amount of air and needing X*Y amount of fuel, we are getting X+Z amount of air (Z being the increased airflow from the smaller pulley) and now need (X+Z)*Y amount of fuel. The reason people's AFR goes up is because sometimes, (X+Z)*Y amount of fuel is more than the injectors can put out. If they can only put out a certain amount, and that is amount is LESS than (X+Z)*Y (what your tune is asking for) then you still have X+Z air, but < (X+Z)*Y fuel which in turn is an increase in AFR. This method of leaning out your tune is hell on the injectors because they will be forced to run at 100% capacity for extended periods of time while even this 100% output is less than requested for your tune, hence why people say you should upgrade injectors when going below a 2.9.
If this is erroneous, plz correct me, but this is my understanding.
Old Mar 16, 2008 | 05:29 PM
HighPSI_LowCC_Speed's Avatar
And as people are saying, smaller pulley doesn't increase AFR. AFR attempts to stay the same as it is a direct function of your tune. It simply says, instead of getting X amount of air and needing X*Y amount of fuel, we are getting X+Z amount of air (Z being the increased airflow from the smaller pulley) and now need (X+Z)*Y amount of fuel. The reason people's AFR goes up is because sometimes, (X+Z)*Y amount of fuel is more than the injectors can put out. If they can only put out a certain amount, and that amount is LESS than (X+Z)*Y (what your tune is asking for) then you still have X+Z air, but < (X+Z)*Y fuel which in turn is an increase in AFR. This method of leaning out your tune is hell on the injectors because they will be forced to run at 100% capacity for extended periods of time while even this 100% output is less than requested for your tune, hence why people say you should upgrade injectors when going below a 2.9.
Although I corrected a couple math-related errors, your logic is otherwise sound! Good info for fresh-on-the-scene forced induction modders!
Old Mar 16, 2008 | 07:41 PM
zinner's Avatar
Moderator Alumni
2 years here.
I dunno why but if you look at all the blown LSJ they all have 60# injectors..
Old Mar 16, 2008 | 07:52 PM
Doc's Avatar
Doc
Originally Posted by zinner
2 years here.
not all the blown cars had 60's...I know of 4 that had 42's.
having said that, its about the driver...
Old Mar 16, 2008 | 08:22 PM
lsjwannabe's Avatar
^^ hm he may be on to something...
Old Mar 16, 2008 | 10:21 PM
Ahh yes, because fuel is a function of air intake. Thanks for the little correction, and I edited my post for future references. Appreciate it
Old Mar 16, 2008 | 10:29 PM
An00b's Avatar
2 years here.
having 60lb injectors also means having custom tuning.....
injectors are just injectors.
they just do what their told.
Jan 12, 2016 12:01 AM
brandon04
Oct 21, 2015 07:04 AM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
