stgII with 2.9?
Old May 31, 2007 | 03:01 PM
braddddddd991's Avatar
stgII with 2.9?
some ??
what psi should i hit?
can you feel a difference?
Old May 31, 2007 | 03:02 PM
Acidangel_5.0's Avatar
17-18 is what i see
Old May 31, 2007 | 03:04 PM
can you feel a power difference
Old May 31, 2007 | 03:33 PM
chipsgt's Avatar
I would think so, if your seeing 2-3 Lbs. over stage II. you SHOULD be able to feel it, but maybe not.
I am also considering this.
Sounds like a good mod, without having to worry about monitoring things closely.
Old May 31, 2007 | 03:39 PM
couldnt really tell you.. i put on the 2.9 as soon as the got the balt home from doing the stg II flash hhe
Old May 31, 2007 | 03:45 PM
R&C_rallySS's Avatar
How long have you had the stage III pulley on the stage II setup? Isnt the stage III pulley a 2.9 or a real close? Also, have you ever had any probs?
I'm thinking my set up will consist of Stage II, Stage III pulley, CAI, GMP manifold, GMP exhaust, GMP dual pass.
Old May 31, 2007 | 03:47 PM
rnjmur's Avatar
It should give you around 10 - 15 HP and 15 - 20 TQ gains over the stage 2 pulley which should make at least a slightly noticable difference.
Old May 31, 2007 | 03:57 PM
i did the Stg II pully swap on my own... ran the car with just the Stg II pully for about 2 weeks before i went and got the injectors/flash/belt added...
car ran fine... with the 2.9 the car still runs perfectly fine... 0 problems.. been like this for about a month now. i think the stage 3 pulley is a 2.9x
Old May 31, 2007 | 04:02 PM
RJSS's Avatar
Do you know what your IDC is? I'm curious about this setup and would consider it if the IDC is low enough.
Old May 31, 2007 | 04:05 PM
Cobalt_SSTuner's Avatar
you had to re-tune your car after putting on the 2.9 correct? or no?
RuSSo-29's Avatar
subscribed
Old May 31, 2007 | 05:55 PM
rnjmur's Avatar
The stage 3 pulley is 2.99 inches. If you have the stage 1 or 2 tune you shouldn't need to retune if you put on a 2.9. However, if you do retune you can probably pull a little more power out of the car.
Old May 31, 2007 | 06:06 PM
RedEcotecSS's Avatar
how about someone do a how-to on this? or is it that simple?
Old May 31, 2007 | 06:17 PM
i put the 2.9" (nherbs) after i did the stage flash... car runs fine and it runs like a bat out of hell... i am currently waiting on an interceptor gauge just to monitor things but im pretty fine on the tuning based on how the car runs + i have elevation in my favor so i am more at ease
Old May 31, 2007 | 06:23 PM
i have an interceptor, just debating on putting a 2.9 on. how hard is it to do and what's involved in the process? any special tools?
Old May 31, 2007 | 06:35 PM
chipsgt's Avatar
^^^ Do you have a stage 2 hub on there? Or is it still stock?
If you have an aftermarket hub, its a 10 minute job. You would only need a 15mm wrench for the tensioner, and then the tools to pull the bolts out of the pulley. Pop the new one on and reverse the process.
Old May 31, 2007 | 06:37 PM
yeah man i have stage 2. what's involved? unbolt x4, bolt x4
Old May 31, 2007 | 06:38 PM
to swap the pulley real quick..
15mm wrench and take belt off
use GM tool to remove the bolts holding on pulley
remove pulle and slap new pulley on
bolt down
put belt back on
take car for drive.. done
Old May 31, 2007 | 06:39 PM
chipsgt's Avatar
You got it!
Just make sure you get a pulley that fits your hub!
Its a pretty painless process.
Working with the belt is what will give you the most trouble. But thats because its a stubborn b*tch!
Old May 31, 2007 | 06:41 PM
so i dont need anything to work with the belt besides some muscle? haha. where's the best place to get the pulley from?
Old May 31, 2007 | 06:42 PM
chipsgt's Avatar
Theres a guy on here, his name is all over the place but it eludes me at the moment.
Maybe Acidangel knows?
Other than that, I am pretty sure ZZP makes them to fit the GM hub.
Old May 31, 2007 | 06:45 PM
i searched and came up with the name nherbst454.. sound familiar? do i need smaller injectors? thanks for all ur help man, i appreciate it. +rep for bein helpful.
Old May 31, 2007 | 06:47 PM
chipsgt's Avatar
That would be the guy!
+ rep for using the search button!
No, the 2.9 will be fine with the 42 lb'ers.
Old May 31, 2007 | 06:48 PM
tREBs's Avatar
does anyone know if you can order just a stag 3 pulley? and if so whats the part number?!
Old May 31, 2007 | 06:50 PM
Thanks chipsgt, your the man! Very helpful information! Thanks a lot bro.
