Stock fuel pump...how much flow?
Old Aug 31, 2011 | 01:32 PM
harryresh's Avatar
So all of these vendors are selling the Walboro 255 lph fuel pump but no one can tell me how much the stock pump will flow??? I've searched the internet and found nothing. Anybody know how much flow or even the pump part number and manufacturer???
Old Aug 31, 2011 | 03:13 PM
mrbelvedere's Avatar
there was a htread on it a longtime ago the stock pump isent that bad it is supposed to be on the same playing field as a walbro 255 hows the car run with the zzp cams
Old Aug 31, 2011 | 05:18 PM
harryresh's Avatar
i forget how you know i have zzp cams. i think i remember we might have talked about it. i love it. they kick on real nice around 4200rpm. im going turbo (Garrett GT3076) and they should complement the turbo nicely. just bought a LSD trans and looking to find wider wheel for wider tires...
Old Aug 31, 2011 | 05:36 PM
u have the stage1 cams dont you u ever get it on the dyno and y go turbo push that tvs
Old Aug 31, 2011 | 07:15 PM
ralliartist's Avatar
Stock pump Outflows a walbro 255
Old Aug 31, 2011 | 07:25 PM
rivaladore's Avatar
Hey op if youre selling the tvs I'm interested in buying
Old Sep 1, 2011 | 06:58 AM
harryresh's Avatar
i did push that TVS as far as 93 octane. i had a 2.7 on it and was hitting boost bypass due to heat. then i dropped the boost with a 2.8 and i was fine. and that was with a dual pass, front mount, and 70/30 meth
already sold
Old Jan 5, 2015 | 09:32 AM
ROADKONE's Avatar
I am hear to revive for my own personal benefit... haha
I've used the search function and this is all I stumble upon...
so maybe someone can give the answer of the question above. "what is the stock fuel pump flow rate?"
or point me to the correct thread that I cannot seem to find.
I am having a fuel pump issue and therefore have decided to replace it.... now I need to figure out if i should upgrade to an AEM/walbro or stick with the stock fuel pump...
eventually I will be stage 3 2.8 pulley 60# injectors.... thats the future.
Old Jan 5, 2015 | 09:44 AM
the stock pump will more then easily handle that even on e but you will need 80s
Old Jan 8, 2015 | 08:45 PM
ROADKONE's Avatar
Thanks
I ended up finding it... I believe we have the Bosch 044 inline FP... Which is a 300lph flow... Took several hours but I found it.
Old Jan 9, 2015 | 10:36 AM
Josh@ottp's Avatar
Originally Posted by Blk N Blu
Thanks
No that is wrong. The stock fuel pump is not inline and is not the bosch 044. It flows about 225 lph and is an in tank model.
Old Jan 10, 2015 | 10:41 AM
ROADKONE's Avatar
good to know. thanks Josh.
Supercharged06SS
Dec 11, 2022 04:47 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
no_ss
Oct 18, 2015 11:58 PM
Oct 13, 2015 09:32 PM
Stuff
Oct 1, 2015 05:47 PM
