Stock Vs GMPP Upgraded Vs SPEC 2+ cluch parts comparo
I have come across several parts as I craigslist and shop online and these are three of the clutches I have on hand and just some impressions. I have actually only ran the stock one thus far but even stock had not slipped on me since turbo'd. I must have got a Wednesday made one.
Stock clutch and pressure plate (I personally was making over 300hp for a short time with no issues on a turbo LSJ)
GMPP Upgraded LSJ c&pp (rated at 300hp but no tq given) 250 internet price, free trade
SPEC 2+ c&pp (rated to 440 lb-ft of torque, but has slipped in some cars with less power) 550 internet price, I paid 200 on Craigslist.
LNF TOB made in the Czech Republic? is an upgrade over the LSJ version
LSJ Tube, Pressure Plate bolts, fly wheel bolts all should be replaced during install.
Stock Flywheel ( I am reusing it, its surface still maintains the ridges compared to a new one) a lighter version can be purchased but the weight can affect drive-ability drastically when lighter than stock fly wheels are used.
I think there is a compromise between pressure plate and clutch material; whereas the stocker and spec use a heavier pressure but compensate drive-ability with the clutch material and the newer gmpp uses a lighter pressure plate but uses a grippier material.
Also the spec clutch discs are thicker than the stock and gmpp, so with the same spring pressure from the pressure plate the spec will hold tighter since its under the load of the spring due to thickness alone, then there is the material that spec uses that would create more friction.
What it all comes down to is the evidence i have here that SPEC uses a stock pressure plate painted blue.
*EDIT, this is all speculation, what I am saying is just an observation.
What kind of power are you making?
gmpp and SPEC are new in the box. these are parts I have had laying around for a while while I have been building the engine. Not sure which would make a better daily driver. I want to use the SPEC cause of the better power handling. Going to hold onto them for now.
The Spec has ground down the stamp that is on the stocker by my finger and painted it blue to help hide it but its very apparent. Then on the opposite the same place has a SPEC emblem covering another area where its ground down and the model is located. I inspected both but there is no doubt that SPEC uses the LuK pressure plate, same as GM.
you cant bench bleed a tob in a trans out of the car, there is no one way valve in the hydraulic system, no way to do it. all you can do is run brake fluid into it, for whatever good that does. But you are correct, all these TOB failures appear to come down to incredibly bad installs and really crazy clutch bleeding...I have never had a TOB fail on an new F35 clutch install on deltas since 2004.
PS I am not confident that Saab used a Luk pressure plate, but for sure the experience with the LSJ says GM wished they had not, they went cheap and for the LNF they switched to sachs.The story goes ( I got some inside info lol) Exedy did the OEM clutch for the Cavvy f23 and GM asked them to bail out the LSJ just as they were going into production and Exedy told GM to take a hike.
