Study Time Slip / Results...
Old Oct 29, 2006 | 07:48 PM
R&C_rallySS's Avatar
If anyone has read my post Born for Glory, the Cobalt SS/SC you have seen I ran my best time at Maple Grove Raceway. The time is again approching and I would like to beat my 14.2 stock time. However this time around I would like to have at least one mod. What would be the point in adding more power if I can not lay down a good 60" time. I noticed with every tenth of a second gained in the 60" I would gain 2 tenths in the 1/4th. To me it would make sense to upgrage suspension and figire out the best way to make a good 60" time. With this said I'm looking at the Ingalls' torq damper and transmission mounts. I would like to hear from everyone who has installed these and if there would be something else you would recomend. All input would be highly helpful. If you could also maybe mention some type of proof other then the car feels better. Anyone add a ingalls and better mounts and see better 60" on their time slips? It would also be very helpful if you could add links and information on the best prices and bang for your buck. The sooner I can research this the sooner I can order my first mod, tomarrow is monday, monday I would like to make my order. Thanks for your time guys and girls.
Old Oct 29, 2006 | 07:52 PM
sunfirejoe's Avatar
are u stock , and the tranny mounts are awesome, but id dish otu for CAB's and lowering, and fornt motor moutn , the torque dampners work great but not fully, i believe in spend the extra and youll get mroe for it
Old Oct 29, 2006 | 07:54 PM
HackAbuse's Avatar
I'd say either a TD, Poly Mounts all around, and/or CA Bushings
Old Oct 29, 2006 | 08:04 PM
patathSS's Avatar
Traction bars get my vote.
Old Oct 29, 2006 | 08:08 PM
Yes, I am stock. Check my sig. My car has 4k miles and is exactly the way it came from factory. 2006 Chevy Cobalt SS/SC. Any of you guys see better 60" with those mods? If so how much, and is it a bad idea to have the torq damper and mounts? Anyone else have these mods?
Old Oct 29, 2006 | 09:16 PM
sunfirejoe's Avatar
i have the mods i jsut dont like the torque brace anymore, i switched to CAB;s and lowering springs and it did more, than my torque brace did, for me, my 60 foots were about .2 better on average
Old Oct 29, 2006 | 09:34 PM
Wow, .2 better works for me. That means if I do the same set up as you on stock power I may even get .3 better 60" since you have more power then I. That = about 3-4 tenths in the 1/4th. !!!! That means 13.8-13.9 1/4th with just those few mods on stock power! Why did you not like the ingalls?
Old Oct 29, 2006 | 10:10 PM
HackAbuse's Avatar
I would be Hella surprised if you broke 14s with a stock balt, i didn't think it was possible
Old Oct 29, 2006 | 10:54 PM
sunfirejoe's Avatar
what i didnt like was the cheapness of it, it worked great, but wa snot my style, it didnt suti the engine bay at all, and once i had my CAB's and lowering i dindt need it,
i took it off and it literally was exactly the same, i still had wheel hop and didnt gain any 60 foot times
Old Oct 29, 2006 | 10:59 PM
It is deff. possible to break into the real high 13s with a Cobalt SS/SC. Its all about the 60 foot. With perfect conditions it is possible. Look at the best 1/4th stock times. Someone has me beat with a 14.1 something. Perfect launch, perfect shifting and power shifting could = a 13.9 or something breaking...
So you did not noctice any differances with the ingalls. If this is the case I will not buy it. I rather but $150 into something else then. You had wheel hop with and with out it?
Old Oct 29, 2006 | 11:03 PM
campo165's Avatar
I ran a 2.212 with a passenger...not too shabby if you ask me. Just so you get an idea of HOW SLOW the track was that night...i still ran a 15.118...
edit: i dont have the ingalls or anything...bone stock
Old Oct 29, 2006 | 11:16 PM
Yea, you may have ran a real low 14 with that 60" Maybe the extra weight in the front helped you hook for the 60". Not sure, anyone else have the ingalls with some comments about it?
Old Oct 30, 2006 | 12:05 AM
sunfirejoe's Avatar
i ahd wheel hop with when enwly sinatlled, wihtout when stock, now i have none, and i just rmeoevd it, but im also running a lowered car, CAB;s and custom traction bars, and all motor mounts
Old Oct 30, 2006 | 12:09 AM
Manny13's Avatar
When I got my ingalls intalled I already had and exhaust and intake. It took away at a minimum 65% of my wheel hop at 1 setting tighter than factory setting. I recommend it b/c you can adjust it for the days you don't want the ride to be too harsh. However, I also recommend the tranny mounts and control arm bushings. With all of these mods put in, I couldn't make the car wheel hop if my life depended on it! However, I must say the car vibrates quite a bit.
Old Oct 30, 2006 | 12:42 AM
chipmonk212121's Avatar
well if you change your suspension... you wont be stock anymore lol you could get different mounts and lower it an inch or two and get 13.9X probably but then you wont have a stock car.
Old Oct 30, 2006 | 08:02 PM
Yea true...very true...
Old Oct 30, 2006 | 08:42 PM
IonSpeedMaster's Avatar
glad somebody pointed that out. Even an airbox mod changes your status from stock to modded
Old Oct 30, 2006 | 08:54 PM
RBC's Avatar
RBC
I to am about to start upgrading my suspension. The only Performance mod(if you want to call it that) is a injen CAI. I am going to start with the full upper engine mount then the tranny mounts and all other bushings I can find for it. I can't really lower it because I travel way to much and I never know the conditions that I will be in. One question that I have is, will the stock axles hold up to drag radials or slicks on a close to stock car?
Old Oct 31, 2006 | 10:25 PM
RBC's Avatar
RBC
any info on the drag radials or slicks on the stock shafts?
Old Oct 31, 2006 | 11:26 PM
Tofu's Avatar
Same philosophy I had and same plan of attack. I ran my best ET (in sig) with a k&n intake and 3" pulley for power. It's always been a rule of thumb that for every tenth off your short-time it equates to around two tenths off in the 1/4. I knew the car had enough power to run 13's it was just getting the wheel hop out of the way. That's when I dumped my money into eliminating wheel hop (JBP CAB's, poly engine mount) and it paid off big time. I was cutting 2.0-2.1 60fts on stock wheels/tires no problem and actually got a 1.9 60ft at HMP (the 1/8th mile track). I wouldn't waste time with an engine mount and go straight to the tranny mount. I rode in a friend's SS/SC with one and it did wonders despite it causing a lot of vibration.
Good luck to you, I know the SS/SC is capable of a 14 flat or even a 13.99 bone stock, if I had been a smaller/lighter person and power-shifted a little harder who knows what would have happened lol.
Old Nov 2, 2006 | 10:32 AM
lol I have an advantage, I only weigh 130 pounds, and I'm only 5 foot 5 inches. I never power shifted at the track, hell I never power shifted at all. Maybe I can nail a high 13 14 flat this Sat. I hope so! Then again my parts may be here on friday and if they make it hear I'm not going to be stock anymore.
Old Nov 2, 2006 | 11:04 AM
Tofu's Avatar
Frkn sweet man! I'm 6'2 and 222lbs now, I was 250lbs at that time though lol. Power shifting works for some, not for all though. I guess it just depends on your driving style and what is comfortable for you.
Good luck man, it'll be awesome to see a stocker rock a 13.99!
Old Nov 23, 2006 | 04:27 PM
Thanks alot, but I have not broke the record....It was nice to dream but I couldn't beat a 14.2. My parts ended up comming after the track day and I have them installed now. I love the ingalls and I love the injen intake. Check out my sig, priceless man haha. Now I need to get Stage II and exhaust and header so I can compete with the modded SS time slips. Can't wait!
Old Nov 23, 2006 | 10:57 PM
FLCobalt's Avatar
look at my mods. traction should be any modders first priority when doing step by step modding for track use on this vehicle.
Old Feb 19, 2007 | 09:51 PM
So true, so true!
