Supercharged Stage Kit-3 from GM
umm im not sure of the exact date... you could probably go look on crate engine depots page in the vendor section and look for the thread talking about it. That would probably tell you the exact day lol.
okay.....everyone seems quite about this....
Does anyone have this kit anyways? or do you recommend it from preformance?
Does that say on the website?, i couldnt find it....
Is the Stage 3 kit covered under warranty? Does it void my vehicle warranty?
Because the Stage 3 kit is not for normal on-highway use, it is not covered under
warranty and will void your vehicle warranty.
http://tunersource.gmblogs.com/Racer...Stage-3-QA.pdf
Go stage 2, you keep warranty. Unless you want to run 100 octane or nitrous (voided warranty anyway) you don't really need stage 3, at least as far as I can see besides the adjustable rev limiter...
All I would do is put the dual pass aftercooler plate (with the extra res) and the stage3 pulley on mine. The PCM is unnecessary (it also disables your A/C when in use), unless you are (as stated above) running high octane or n2o
z28addiction
Sep 28, 2015 12:03 AM
