Supercharger Bolt
Supercharger Bolt
Anyone know where I can pick up new supercharger bolts? I'm talking about the 4 that hold the supercharger down to the intake manifold.
From this it appears the part number would be
11589214
However I still can't find a website that carries them.
11589214
Last edited by Zach06CobaltSC; Mar 10, 2010 at 01:13 PM. Reason: Automerged Doublepost
Zach you can just take one bolt out of the top too that where lose, and walk into an y hardware store, ace, true value, menards, homedepote, lowes. ext ext, and make the thread pitch and eureka there you have it 4 new bolts that only cost you a hand full of dollars.
Not a bad idea lol, however I might not be able to get them out considering a shop used an impact putting them in, hence probably why the bottom 2 are so damn tight and damn near stripped.
Meh, I'm not 100% sure which guy did it but we had 3 different people try and get them off and none of us could do it so tomorrow when I get the 18s put back on and take the snow tires off I will have them impact it out real quick and hand tighten it down. Then I will run and see if I can't find new ones. Otherwise I found some from a gm dealership at 8 bucks each but there stock obviously.
If yours are stripped and stuck, just use vicegrips and turn em out at the hardware store. Be sure to bring a small socket set to put the new ones back in though. :-)
