Supercharger issue.
yea i think its from the dirt that gets built up on it combined with the heat an tarnished oxidation. you can remove it with some mothers polish and some long long amounts of elbow grease, i took mine off sanded it and painted it so it looks better and i don't have to worry about it, plus the added benefit of porting it and filling the silencer holes when it was off was a definite bonus
Ahh, thank you guys very much! I'm gonna try this!!!! I thought it could've been my heat exchanger pump causing it to overheat or run hot, but I checked it out & everything looks fine. No leaks or anything.
just paint it...i have engine bay pics on here i think, if not i have some on my myspace. www.myspace.com/k2marine sand it down fairly well and use a textured spray paint, it came out great..
just a tip, i used a textured spray paint, but they arent heat rated....so what i did was i sprayed the supercharger with black engine paint first then with the textured paint, then i sprayed engine clear coat over top of that, i was worried at first but its holding up great, plus i ported it so it barely ever gets hot, and don't forget to seal your silencer holes with some quicksteel while your down there
Gene, that's really nice
HIV, your blower has aids, it's normal for it to change colors, T-cell count issues usually.
Na, it's just oil residue. Not sure how it gets there, but i've seen it on some cars.
i just picked up a ported SC and had it painted been on for 3 days so far its clean haha
but i was having the same problem as you were with it turning gold ish it stopped me from opening my hood and the car meets i went to lol
Nice that is hot! Yellow is my favorite.
Since you have a real SC car... and not a hybrid, lol, like mine... where is your level at, hot and cold in the stock filler neck?
I just want to make sure my level is ok, etc. Been checking it out every night since I've installed my setup to make sure.
thanks alot man
and ass for the filler neck i tried to check it but its to dark out side right now but im pretty sure its about 3/4 of and inch from the bottom but i havent checked it in a while ill take a look tomorrow and let ya know
Ok, np thanks. I know there is a hot fill line, but no cold. Weird.
