supercharger silencer holes
Hey, anyone ever plug the silencer holes on the supercharger? if so, what is the safest way to do this, tig welding seems to be the only thing i could find. also how much of a change do these holes being plugged make? thanks for all the help!
yup, i did, and no, NEVER weld on the supercharger, it will distort the metal, the best way to do this, is to use JB WELD, mix it up, and press it in. When you do it the rotors need to come out of the supercharger and you need to sand down the inside of the housing to make sure the JB Weld isnt touching the rotors as they pass.
There has been many many topics on it.Use this to find it.
https://www.cobaltss.net/forums/search.php
I second the epoxy method. Only try and find stuff called QuickSteel. It has a higher temp resistant and fully cures in an hour. Advance Auto sells it as do most hardware or autoparts stores. Make sure you take the rotors out and sand down the inside bottom of the epoxy plug really well. The clearances inside are really tight. Also put some duct tape inside soo that it doesn't leak to the inside. When pulling apart the snout be careful to only pull both the snout and the middle piece out of the main housing. If you pull just the snout, you will lose all of the supercharger oil, and need to purchase more oil to fill it. I put a big clamp on the snout and middle piece, and did not spill a single drop of oil. Good luck, its a definite sound improvement. Only think that I didn't like was that it makes the blower louder at idle and it makes a weird rattling sound. Kinda reminds me of some marbles rolling around inside there... If you want pics check out my VBGarage...
I did this to mine, HUGE improvement in sound. Even in normal driving if you get on it a little you can hear it. And I only have an airbox mod, with a metal intake i'd imagine it would be a lot louder.
OK, the marbles comment is an exaggeration... There is a bit of sound, but nothing too bad. My car only has 7000 miles on it. I taped off the bearing area soo that I did not have a problem with losing any grease. BTW what type of grease should be used? I did not add any additional grease as I saw no point to. As fas as the coupler is concerned, I didn't crack open the snout at all. I clamped it and pulled the whole assembly out of the main housing. My coupler surely shouldn't be bad after that little mileage..?
Ummm my supercharger started making the "marbles" noise at around 8000 miles and I'm completely stock! I'm taking it to the dealership to make them replace the coupler thanks to the advice of rrutter81
HAHA i always kinda liked the funky sound my blower made at idle.
When you sand down the "steel" a bunch of grit and dust gets in the bearings. I cleaned mine out with damn near a full can of brakleen and regreased them with wheel bearing grease. Looks good as new.
When there was dirt in them it had that marble sound, and it felt gritty when I turned the pulley because of all that **** inside the bearings. Luckily I noticed before I reinstalled the blower.
LOL yea that's not a normal motor sound. It's not good. I get the distinct feeling I'm going to be spending a lot of time on the phone with GM in the near future over this LOL. But hey every time I call them and complain they give me a year of OnStar for free or a free GMPP service package which covers my oil changes and basic maintenance so I'm not gonna bitch about having to call them too much LOL
I put a piece of duct tape over the bearing end of the blower. Using this method I was able to port the blower and fill the holes with QuickSteel without worrying about screwing up the bearing. I cleaned everything thoroughly with compressed air and brake parts cleaner before removing the tape and reassembling it all. Just an FYI. I don't think re-greasing the bearing is needed if they are not messed up.
would it be possible to stuff a rag or clean cloth into the bottom of the housing where the bearings are to prevent shavings and what-not from going down there while porting/plugging? would that be a little better than some tape?
3m tape is best man.... u wont get a nice enough seal with a rag.
ive got the supercharger apart last night, and tommarrow im going to begin porting it slightly, and plugging the silencer holes. so i guess its not a bad idea to port or atleast polis the inlet to the supercharger, and possibly the throttle body? all of these are my spare parts, so its really just an experiment, but if it helps a little id be down for it. thanks for everyones help too!
z28addiction
Sep 28, 2015 12:03 AM
