Which TB is better/larger diameter?
Old Apr 15, 2008 | 02:56 AM
domin8_gt's Avatar
I tried searching, but couldn't find the answer I was looking for. Don't know if it is because my search wasn't good enough, or if this question hasn't been asked yet.
Anyways, which throttle body has the larger diameter on the inside? The LS4 throttle body, or the Saturn Motorsports throttlebody.
Old Apr 15, 2008 | 08:22 AM
QuikSilverSS's Avatar
I have never heard of the Saturn Motorsports TB, but the larger LS4 TB works on the Cobalt SS/SC, you will need to buy the Rebel Autoworx TB Spacer or have the supercharger opening ported where the TB attached to, also you will need to change the ETC Scalar Area under Idle in HP Tuners for this mod to run right. Also this mod will lean the A/F mix out almost a full point so it would be advised to add a bit of fuel in HP Tuners to adjust.
Also the car will be extremely touchy to the throttle, just be warned you will need to relearn how to drive the car, its insanely touchy on the gas after this mod
Old Apr 15, 2008 | 08:35 AM
2K5SS/SC?'s Avatar
Does anyone know where I can get the LS4 throttle body and roughly how much it cost? I checked ebay, but I can never find anything on there. I would like one to do the swap, but I can't find one!
Old Apr 15, 2008 | 09:10 AM
LopsidedJester's Avatar
Saturn motorsports is only a tiny bit larger than the stock throttle body cause its been bored out slightly, and it has a better valve plate. I've heard testimonies that there isn't much of a difference and for a couple hundred dollars its definitely not worth it unless you have gone and done everything you can to your car already and don't want it custom tuned.
The LS4 throttle body is .5" bigger in diameter and is a bit of overkill if you don't have a lot of mods and supposedly makes your car more jumpy like QuikSilverSS mentioned, but it will get you some hp if tuned correctly (you for sure need to get tuned when installing this mod though). However the saturn motorsports throttle body does not require any PCM tuning.
If you're buying an LS4 throttle body, they're worth no more than about $55, but on ebay you can find them for cheaper sometimes.
Old Apr 15, 2008 | 11:44 AM
freakta's Avatar
I'm gonna be needing one soon also so I'll search around and see if I can find a couple
Old Apr 15, 2008 | 12:28 PM
quadracer0387's Avatar
i have the raw spacer for sale brand new comes with the longer bolts...
pm me if interested
the ls4 tb is fine to run, you just have to be tuned for it to get the jumpyness out.... thats all
Last edited by quadracer0387; Apr 15, 2008 at 12:28 PM. Reason: Automerged Doublepost
Old Apr 15, 2008 | 12:29 PM
pm me if interested
ya I forgot to mention this in my previou post, tuning can take away the jumpiness
Old Apr 15, 2008 | 12:33 PM
you can also find one used for fairly cheap in good condition
Old Apr 15, 2008 | 01:34 PM
Area47's Avatar
Rent me! per hour
the tb scaler controls the jumpy-ness of it
Old Apr 15, 2008 | 02:06 PM
adjusting timing on the low end helps also
Old Apr 15, 2008 | 04:07 PM
brandon2.2's Avatar
ALL of these throttle body's are identical:
LS4
4.2L I6 (trailblazer)
3.7L I5 (colorado/Canyon)
same part number and everything.
http://cgi.ebay.com/ebaymotors/elect...spagenameZWDVW
Last edited by brandon2.2; Apr 15, 2008 at 04:07 PM. Reason: Automerged Doublepost
Old Apr 15, 2008 | 11:23 PM
2K5SS/SC?'s Avatar
^^^Damnit! I forgot to bid on that one before I went to bed last night!
Old Apr 16, 2008 | 04:05 AM
domin8_gt's Avatar
Awesome! Thanks guys. I was wondering about the TB because I'm trying to blueprint the build I want to do on the SS/SC. Since the LS4 TB is larger I will def go with it. I know I will need tuning and was planning on machining the snout to match the diameter of the TB. Now I just gotta find a TB spacer with the same diameter that is already tapped for meth injection like the Cobalt Addiction one is. I think all this along with exhaust and the TVS s/c will make for some decent numbers when tuned.
Old Apr 16, 2008 | 10:20 AM
freakta's Avatar
I can't seem to find anything
Old Apr 16, 2008 | 10:30 AM
lsjwannabe's Avatar
i ported my ls4 tb not the tvs, that is fine.
TurboWood
Sep 7, 2015 11:08 AM
Badmunky
Mar 16, 2015 12:13 PM
NJHK
Dec 10, 2006 08:32 PM
2K5SS/SC?
Oct 15, 2006 12:44 PM
