View Poll Results: Which set-up is the best all around
Twin Charge
14
22.22%
Turbo
39
61.90%
SuperCharged
15.87%
Voters: 63. You may not vote on this poll
Tc Vs. Sc
Tc Vs. Sc
Ok heres my thoughts and maybe will help with some other people questions.
I have the 2.0 Lsj and I want to have about 475 Fwhp w/o spray.
I was think about doing the twin charger setup but seems to have troubles so far. So then I was think about the tvs but I havent seen over 350ish. On the other hand you have guys with turbo kits running 420ish.
What has the best potential?
I am thinking I will end up turbo but if we figure something out about the twincharge I think I might just do that. I want the sound of the SC but the TC has the potentail
Turbos make more HP due to the parisitic power loss you get with a supercharger. (they have to take HP to make it) Where a turbo is free HP, for the most part.
Twin charging might neet but I don't think it'd be worth it.
MY PERSONAL OPINION.....
Twincharge has the most potential as you can put a gigantic turbo on there and use the supercharger to spool it so that it is actual usuable power. But the downside right now is tuning and such. If you get it to work though, it will be phenominal.
Turbo will be the easiest way to make 400+whp.
Supercharging will net you 0 lag and probably make for the "funnest" street DD car. But that's also opinionated. Plus it will take quite a bit to get 400+whp out of supercharging.
someone already tried it and it was pretty much a massive failure. It was real laggy when making power and it didn't really make a lot of peak power. It was like having a giant laggy supercharger. All the pitfalls of both turbos and supercharging. I'm sure if someone put a properly sized procharger on though, they could probably make it a success. But no one wants to put the money into it since it costs so much and you can go TVS or turbo for much cheaper.
Ya true, there are alot of things to consider. but if possible wouldnt it make some impressive power??
Thanks never seen anything about it.. I know the v8's make alot power with them though..
Last edited by SPRCHRD2007; Dec 9, 2008 at 05:03 PM. Reason: Automerged Doublepost
Here is the car for sale. 236whp on 12psi. WEAKSAUCE.
https://www.cobaltss.net/forums/show...ght=procharger
the he claimed it only made 220whp here. so I dunno, it was a fail thing.
Last edited by ralliartist; Dec 9, 2008 at 05:24 PM. Reason: Automerged Doublepost
good try though.
With the TVS and enough engine and head work. Maybe?
