Cobalt SS Network
Cobalt SS Network (https://www.cobaltss.net/forums/)
-   2.0L LSJ Performance Tech (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/)
-   -   testing o2 sensor? (https://www.cobaltss.net/forums/2-0l-lsj-performance-tech-47/testing-o2-sensor-189356/)
Sh0nuff Sep 19, 2009 01:24 PM
testing o2 sensor?
How can you test an o2 sensor to see if it's gone/going bad?
Zach06CobaltSC Sep 19, 2009 01:36 PM
Generally you will throw a code if it's out. As far as testing it, They can be tested both in the car and out. If you have a high impedance volt meter, the procedure is fairly simple.
http://www.gnttype.org/techarea/ecms...O2sensors.html
Read through that.
boostedss26 Sep 19, 2009 01:44 PM
Hook up a scan tool, not a code reader, and see if it's reading.
Sh0nuff Sep 19, 2009 01:46 PM
FYI I get like 33mpg average.
hmm would the scanner they use at autozone be able to check that?
Sh0nuff Sep 20, 2009 12:17 PM
What are the signs of a bad o2?
I get backfires shifting to second...
WOT had a good size backfire when shifting to second and another from second to third...
Car seems to be running very rich.
Often causing a bogging down feeling.
downstream o2 would not effect drive-ability if it went bad correct?
Upstream o2 could go bad and cause drive-ability issues without throwing a cell correct?
