testing o2 sensor?
Old Sep 19, 2009 | 01:24 PM
Sh0nuff's Avatar
testing o2 sensor?
How can you test an o2 sensor to see if it's gone/going bad?
Old Sep 19, 2009 | 01:36 PM
Zach06CobaltSC's Avatar
Generally you will throw a code if it's out. As far as testing it, They can be tested both in the car and out. If you have a high impedance volt meter, the procedure is fairly simple.
http://www.gnttype.org/techarea/ecms...O2sensors.html
Read through that.
Old Sep 19, 2009 | 01:44 PM
boostedss26's Avatar
Hook up a scan tool, not a code reader, and see if it's reading.
Old Sep 19, 2009 | 01:46 PM
Sh0nuff's Avatar
FYI I get like 33mpg average.
hmm would the scanner they use at autozone be able to check that?
Old Sep 20, 2009 | 12:17 PM
Sh0nuff's Avatar
What are the signs of a bad o2?
I get backfires shifting to second...
WOT had a good size backfire when shifting to second and another from second to third...
Car seems to be running very rich.
Often causing a bogging down feeling.
downstream o2 would not effect drive-ability if it went bad correct?
Upstream o2 could go bad and cause drive-ability issues without throwing a cell correct?
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
tomj77
Oct 4, 2015 11:39 AM
jmelton327
Sep 26, 2015 10:04 PM
