Bad idle.
Old Sep 28, 2015 | 06:41 PM
tomj77's Avatar
Bad idle.
So today my car decided to start idling like crap. Did boost leak test, no leaks. It goes lean when it stumbles at idle, unplug maf, runs smooth, plug maf in, runs like crap. Ideas?
Old Sep 28, 2015 | 08:02 PM
63 Nova SS's Avatar
Is the maf bad?
Old Sep 28, 2015 | 08:26 PM
tomj77's Avatar
Doubt it, i think its a fuel pressure issue, my pressure at idle is lower than normal, and I couldn't here the ticking, then the ticking started and idle got better and fuel pressure went up. But it's still not normal but better. It's a new pump I hope it's not bad
Old Sep 28, 2015 | 09:14 PM
63 Nova SS's Avatar
How much have you drove it since changing the pump?
Old Sep 28, 2015 | 11:40 PM
tomj77's Avatar
3 weeks about. been running great till today.
Old Sep 29, 2015 | 06:49 AM
You need to log and look at desired fuel pressure, fuel pressure, map sensor, throttle position, timing advance, rpm, target idle rpm, MAF lb/min, VE lb/min. I think thats everything, then start comparing to what your tune calls for vs what you're seeing.
Old Sep 29, 2015 | 08:06 AM
slapbetcommissioner's Avatar
I wonder if it's just the cool temps. Maybe the tune needs some adjusting?
Old Sep 29, 2015 | 11:47 AM
tomj77's Avatar
That's the plan, will log today.
Old Sep 29, 2015 | 11:49 AM
tomj77's Avatar
No it's been this cool before and it didn't do it. If I drive the car a while and then stop and let it idle, it's ok for about 20 seconds then it starts going weird. Vacuum acts funny. From -21 to -18 back and forth. Maybe my tb is going? I'll log today and that should tell me
Old Sep 29, 2015 | 12:35 PM
Misfires will cause the vac to move around
Old Sep 29, 2015 | 01:02 PM
There are all kinds of things that will cause the LNF to idle funny. Incorrect DAL, MAF base table, EXH INT cam tables, Opt Spark, Opt torque. Needless to say it can be a little hairy to figure out
Old Sep 29, 2015 | 01:56 PM
tomj77's Avatar
I'll do oil change and spark plug change on weekend as well, spark plugs have been through some abuse so see if that helps. Did see misfire in cylinder 1 and 2 a little on gauge. Will double check it on hp tuners cause gauge isn't very reliable for misfire issues unless they is big
Old Oct 1, 2015 | 01:58 PM
tomj77's Avatar
Well today I do compression test and change plugs. Now my turbo sounds funny under boost. I'll be checking that as well. This is starting to get annoying. Guess I'll check for boost leaks again check my intake for leaks, probably check pcv system Saturday since idle issue seems to clear up when I take the oil cap off mostly. I don't know why my car can't just throw a cel ever when I have an issue so I know where to start lol.
Old Oct 1, 2015 | 08:03 PM
tomj77's Avatar
Compression test good, pcv is the suspect now, been getting some weirdness from that. Turbo weird noise due to dented charge pipe causing leak at turbo. Don't tighten clamps to tight lol
Old Oct 1, 2015 | 09:08 PM
T-fog's Avatar
^ This is how i got my injen intake for $60 bucks lmao
Anyways I picked up a oem tail pipe exhaust expander and heated the pipe with propane and went to town.
Hope this helps, Sorry I am no help since i am still learning about these cars myself, But keep us posted
Old Oct 1, 2015 | 09:53 PM
I used that trick, minus heating it on my hot side charge pipe. Had a nasty boost leak due to the previous owner tightening the lower clamp to much. Rented an exhaust expander and boom perfect fit
Old Oct 1, 2015 | 10:37 PM
tomj77's Avatar
hmmm, where do I get exhaust expander? this isn't the first pipe iv dented, that k&n intake is super easy to dent lol
Old Oct 2, 2015 | 06:21 AM
I rented mine from an O'Reilly's. If you can just pull the pipe and bring it in. It won't take longer than a min and a little effort
Old Oct 2, 2015 | 11:03 AM
tomj77's Avatar
I spoke to soon, turbo still makes funny noise At mid to full boost. I really hope he bearing is ok. Checked for shaft play a few weeks ago and it was good, guess I'll check again
Old Oct 3, 2015 | 06:35 PM
tomj77's Avatar
Well intake valves don't look to good. Even with Powell separator oil still getting in from pcv valve but mostly carbon buildup from combustion gases it seems. Intake manifold was pretty clean. Probably cause of meth. Gonna blast em again
Old Oct 3, 2015 | 11:10 PM
tomj77's Avatar
Well did lots of work today. Oil change, checked bpv, intake, few other hoses. Changed o2, cleaned rear o2, Walnut blasted valves, cleaned intake mani and tb. Idle is good now it seems, shall see on cold star tomorrow. Turbo still has a funny buzzing type noise at high boost but goes away after a little bit at full boost. Just don't get it. Should probably check for exhaust leaks maybe
Old Oct 3, 2015 | 11:31 PM
tomj77's Avatar
woohoo I found issue.....hopefully, one of the nuts that bolt turbo to manifold back off causing exhaust leak. probably the exhaust squeezing past gasket I'm hearing. gonna let it cool down and torque it back up and see what happens.
Old Oct 4, 2015 | 06:30 AM
63 Nova SS's Avatar
Good deal, I hope that's it. Surprised with the separator and meth that you still had dirty valves.
Old Oct 4, 2015 | 09:14 AM
Did you clean your intercooler prior to installing the air oil separator?
Old Oct 4, 2015 | 10:06 AM
tomj77's Avatar
Yes I cleaned the intercooler and pipes. This was a year ago. The valves weren't black with oil like before they were gray. The valve itself wasn't to bad, the stem had crusty buildup though. It came off pretty easy.
