Thc's Build Thread
Thc's reBuild Thread
well i figured id make this thread since i started reinstalling my motor today.
my mods are as follow
je pistons .020 over stock bore (w coating)
ported head
60lb inj
3in pulli
zzp midlength header w 3in. downpipe
hahn 3in cat back
injen intake(soon to be rebel 3in)
zzp fmhe w dual pass and custom stainless option b(not finished)
also i have a aem wideband,aem boost guage, and hptuners pro
heres some pics
oops! hope this isnt to expensive
ill post mor pics when i get them. right now the motors in and bolted up.tomorow im going to be ordering the rest of the stuff i need and reconnecting all the wires and hoses.
hopefully i can have her running in the next couple of days.
ported head
60lb inj
3in pulli
hahn 3in cat back
heres some pics
no offense. but other that the pistons being .020 over bore. this isn't really much of a "build". unless there's other things you haven't mentioned. hopefully you go bigger and better on your rebuild after your sleeves crack and shatter
no cryo doesnt help as much as everyone thinks in my opinion. im just going to have to get a quote from my uncle for some machine work and pull the motor again when i have time.
ya i guess your right not much of a build. i have more plans but the pockets are only so deep know what i mean.
i dig it. looks like the 75 hours a week im going to be getting the next couple of months in texas is going to more motor work. or taxes almost forgot about that
well since no mail on the holidays i started bending the tubing for my stainless cooling tank.heres some pics.i will be orbitally welding the hose barb fittings to the tubing.the lines are 3/4"ss .065 wall.im probablly not going to have time to make the stainless resavoir before i go to texas for 3 weeks for work so ill finish then.
i will also be installing b&g coilovers when i get back. ill make sure to take pics and all that good stuff. on to the pics
these are the hose barbs i will be using
this is the feed line
the return line is tucked behind the washer fill spout
