Is there any clutch adjustment?
i put a SPEC clutch in and now the clutch doesnt catch until the clutch pedal is all but the whole way up. is there any adjustment for this? its harder to control when your foot is off the floor and and you have to lift your whole leg before it starts grabbing. :(
i don't think that there is from the outside....
you may want to try to bleed the system again see if that helps
i was actually wonderinbg about this as well cause ive noticed that since its gotten warmer out it almost feels too easy. still grabs near spot ive been used to but i seem to slip it more than i was used to .
you might want to look into zzp adjust clutch rod. sometimes with stiffer clutchs the clutch rod can get bent. you should see some of the pics people have of their bent rod..... no homo lol
Originally Posted by Jrhdpaintball
(Post 4831365)
Originally Posted by rollingboostedss
(Post 4831260)
im pretty sure thats normal both of my spec stage 3 clutches engaged at the top of the pedal travel.
