They Rigged my car help!
Hey every one i have recently bought a 2006 SC SS cobalt and its says it a stage 2 on gms papers and it looks like some things are unplugged and i would love to know why first the Evap line is unplugged the one that goes to the throttle body and when i found the line it had a bolt in it ...... so i naturaly took out the bolt and plugged it back in um big mistake i ran it around the corner and off to a friends house i noticed a loss of power so i tested that fact i ran it hard and maxed out the boost at 13.5 and before i did that it would boost at 14.9 i was like eh loss off power is better if it runs better witch it seemed to do until the trip home......... the car started acting iradicaly when i went into first its was broncoing and i couldn't stop it i shifted higher and up'd the throttle got the revs high and it stop at around 4k RPMS.. i put it in neutral and i swear the engine sounded like it was choking the revs were bouncing hard core from around 200-2000 it was going nuts i swear if i left it like that it would shut off so when i got home i toke the line off and put a screw back in it but i hate running things rigged can some one help there is also another line that is missing but i don't even know what it is all i can tell u is that its a barb on the far left side of the engine. There's also another line in my air intake that has a bolt in it also please help guys ...and sorry for the bad English and grammar
if you just bought it from a dealership, you got screwed cause i think florida's law is on an as-is car once you drive it off the lot, it's yours no matter what. if you bought it from a private party, the same applies.
now that you know you screwed up, go ahead and take it to a mechanic and have them do a full check.
Lol. Shouldn't have taken the screw out. Some times it is important to block off a Vac line if the tune on the car is not tuned for it. Saw this same ghetto setup on a friends supra with a big turbo... put the car back the way you found it.
I toke the car today to Autozone to take a look at the Engine light on it has 2 O2 Sensors and a Supercharger Sensor bad or notpluged in are these things to worry about ive only worked on Carbed engines i was a real V8 kinda guy but i wanted to get into the Tuner Gig before i was to old and i know on Carb engines i can look at an O2 Sensor and kick it cause its usless!
you need every little sensor on this car or else you will throw a code. i would say plug everything back in and drive it to a gm dealer and get them to reflash you stage 2 tune. or find someone with hp tuners and let them fix everything
