For those with Meth Injection
Old May 9, 2008 | 04:21 PM
XbandiniX's Avatar
Whats are you guys using to spray? What brand of washer fluid is good to use?? I really don't feel like paying for devils own ****. The only washer fliud i have seen that has methanol in it krystal kleer but i don't know the %'s.
Old May 9, 2008 | 04:22 PM
M-Dub's Avatar
I use regular -20* washer fluid (the blue ****) and Yellow bottles of HEET!
Old May 9, 2008 | 04:29 PM
invisible's Avatar
I used 100% pure methanol and water.
Old May 9, 2008 | 05:35 PM
XbandiniX's Avatar
ok kool. whats the brand M-dub? is it krystal kleer??
Old May 9, 2008 | 08:09 PM
AIS's Avatar
AIS
Non Authorized / Non-Supporting
Be sure to read our article which goes over other types of fluids you can use and sources for which you can buy it from. In this article there are two links to two different companies which will sell you 5 gallons of pure methanol for $70.00 shipped to your door. By mixing this 50/50 with water, this will give you 10 gallons which would last you the better part of the year for only $70.00.
Here's the link
http://www.alcoholinjectionsystems.c...icle_info.html
Rodney
Old May 9, 2008 | 08:41 PM
XbandiniX's Avatar
thanks
Old May 9, 2008 | 08:42 PM
M-Dub's Avatar
Any non additive mix washer fluid is just fine... as long as it is -20* the other has de-icer in it which isn't good!
Old May 9, 2008 | 08:43 PM
Sunburst_SS's Avatar
If you're going to use washer fluid....make sure it is the stuff for -20 degrees. Also make sure it is the cheap stuff meaning no bug cleaners and crap like that.
Old May 9, 2008 | 09:40 PM
freakta's Avatar
boost juice
Old May 14, 2008 | 11:17 AM
AIS's Avatar
AIS
Originally Posted by freakta
boost juice
Boost Juice is convenient. However, it's not as great of a deal as you would think and there is another alternative which will get you over twice the amount for only $10.00 more dollars.
You can have 5 gallons of pure methanol shipped to your door for about $10.00 more then boost juice. Boost Juice is basically a 50/50 mix of water and methanol. So your essentially buying 2 gallons of water and two gallons of methanol. This is convientiant as you do not have to mix it your self. However, it doesn't make much sense to ship water around as you can pick it up locally.
In our article "What Type Of Fluids Can I Use With My Water Methanol Injection System?" there are two links to two different companies which sell 5 gallon drums of pure methanol for $70.00 shipped to your door. Mix this 50/50 as you need it and you will have enough methanol to take care of you for the better part of the year.
Here's a link to the article...
Old May 14, 2008 | 11:40 AM
2K5SS/SC?'s Avatar
Pure meth and water mixed to a 50/50 ratio with a dash of Groovy Grape scent!
Jan 12, 2016 12:01 AM
yellow dragon
Sep 28, 2015 09:49 PM
goaliemo
Sep 28, 2015 01:37 PM
SlowSaturn
Sep 28, 2015 11:03 AM
Sep 27, 2015 08:53 PM
