For those without cats.!!!
Old Dec 31, 2006 | 01:11 AM
hatrickstu's Avatar
all of you that are running catless DP's, are you guys getting CEL's from it?
Old Dec 31, 2006 | 01:15 AM
Shortbus's Avatar
Yea but disabled it with hp tuners.
Old Dec 31, 2006 | 01:16 AM
hatrickstu's Avatar
you were running alot of other stuff as well though right?
Old Dec 31, 2006 | 01:18 AM
HackAbuse's Avatar
I didnt get a CEL in my 2.2
Old Dec 31, 2006 | 01:21 AM
Shortbus's Avatar
Yea.
Old Dec 31, 2006 | 01:25 AM
hatrickstu's Avatar
i have also heard of MIL O2 sensor elimintators. anybody using one of these, and if so where did you get it?
Old Dec 31, 2006 | 03:36 AM
SilverSS/SC's Avatar
Hehehe yea . I get the p0420 code set about 2 times a day . I jus clear it with my aeroforce . Rob was supposed to disable the code for the rear 02 sensor in the PCM last time I was down , but forgot to .
Old Dec 31, 2006 | 03:42 AM
sethallen's Avatar
man i hate cats...im glad i dont have one
im allergic
Old Dec 31, 2006 | 03:29 PM
Matty's Avatar
Was getting 3 different codes. HPTuners got rid of them.
Old Dec 31, 2006 | 03:38 PM
JohnnySasakiMGS's Avatar
im allergic
Old Dec 31, 2006 | 06:45 PM
yellowcobaltss05's Avatar
my codes come and go
Old Dec 31, 2006 | 07:11 PM
BaltM62's Avatar
i have had a solid cel since the day after i put my catless dp on. and im not highly modded
Old Jan 1, 2007 | 01:50 AM
There arent any 02 sims availible for us . The older OBD2 sims arent compatible with the newer GM's .
Old Jan 1, 2007 | 01:23 PM
Blown 4-banger's Avatar
P0420 (emissions system low efficiency)
P0141 (HO2S2 Heater system low voltage sensor 2 bank 1)
P0140 (HO2S2 Heater system inactivity sensor 2 bank 1)
P0036 (forget which one it is but I got this code a lot too)
Those are the code I got after removing the cat and rear O2 sensor.
Old Jan 1, 2007 | 03:23 PM
bamfnss's Avatar
I tried the spark plug antifoulers, and it didnt work at all. HPtuners is the best bet.
Old Jan 2, 2007 | 11:47 PM
cobaltss12's Avatar
Question for the catless dp...
When the CEL is thrown... do you have to get it reset? Will it hurt anything if you dont get it reset? How much HP did you gain? Inspection?????
Old Jan 3, 2007 | 12:12 AM
hatrickstu's Avatar
yeah is it ok to drive around with it, or does the computer adjust and pull timing or anything of the sort?
Old Jan 3, 2007 | 12:15 AM
Matty's Avatar
My understanding is that it just a "warning" and there isn't any adverse effects.
Old Jan 3, 2007 | 01:14 AM
hatrickstu's Avatar
thats what i figured, but i hope its true!
Old Jan 3, 2007 | 01:17 AM
I wouldn't drive around with a cel for very long. Should you get a REAL cel you'll never know it.
Old Jan 3, 2007 | 01:21 AM
hatrickstu's Avatar
very good point. i guess ill put it on see how it goes for a couple days and proceed further. i know there is a couple guys around here with HPtuners. but is there a way to just use HPtuners to get rid of that code and affect absolutely nothing else?
Old Jan 3, 2007 | 01:29 AM
Yeah, just take your current tune, disable the cels your getting and re-flash your car. Nothing with change except the disabled codes.
Old Jan 3, 2007 | 01:34 AM
hatrickstu's Avatar
ok so the "tuner" should be able to read the thrown code, go in and disable ONLY that particular code? no need to touch ANYTHING else?
Old Jan 3, 2007 | 01:35 AM
Yep
hatrickstu's Avatar
Yep
sweet
