throttlebody help....
Old Sep 29, 2007 | 09:58 PM
Kennyspec's Avatar
Hey i was driving the other day and my car went into limp mode and i get these two codes....
[PCM] P1516 - Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance (SES) (Pending) (History) (Immature)
p2101 throttle actuator control motor circut range/performance
anyone else have these problems???
Old May 11, 2008 | 03:33 PM
gunitpg1's Avatar
yes i got Code P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance -PCM.
Does anyone have any idea where this module is??
Old May 11, 2008 | 03:43 PM
ItalianJoe1's Avatar
On the TB itself.
Old May 11, 2008 | 03:52 PM
lil_kano's Avatar
Do a crank postion relearn and clear the code/s.
Old Jun 8, 2010 | 09:18 PM
conerboner's Avatar
My car is doing this now. Does the crank relearn help solve the problem?
Old Jun 8, 2010 | 09:27 PM
conerboner's Avatar
already tried a new throttle body and ecm and that wasn't the issue. checked the wires and they're all good. I haven't checked the pedal itself yet, I'm going to check that tomorrow. Thanks for the help.
Old Jun 8, 2010 | 11:55 PM
Jmoney's Avatar
check if it plugged in. make sure it's clean and if that doesn't work replace the tb. I had to replace the tb. Then the car was fine and finally could get full boost.
Old Jun 9, 2010 | 08:24 AM
conerboner's Avatar
I already tried a brand new throttle body and ecm and it didn't work. I think there might be a short in the injector or something or else the gas pedal itself...
Old Jun 9, 2010 | 09:27 AM
insylem's Avatar
Clean throttle body?
Old Jun 9, 2010 | 09:30 AM
conerboner's Avatar
thanks for all the help guys. The problem was actually with the pump for the liquid to air intercooler. I put a terminal into the fuse box in a spot that had power with key on only and for some reason it was messing with the circuit to tell the throttle body what position to be at.
selfinfliction
Jan 6, 2010 11:53 AM
glen229
Aug 4, 2009 07:59 PM
jhop16
May 4, 2009 07:19 AM
misfitcobalt
Feb 16, 2009 09:50 PM
Kennyspec
Nov 24, 2008 05:02 PM
