Ticking noise after beating on it?
Old Apr 13, 2010 | 07:02 PM
YEW FAIL's Avatar
not all the time but sometimes when i drive it hard, wen i slow down ill notice an idle ticking almost like a diesel engine just not to that extreme but as soon as i restart the car it goes away.
anyone else have this same issue?
Old Apr 13, 2010 | 07:13 PM
selfinfliction's Avatar
you've burnt up a muffler bearing, buy 4 gauges and it'll fix the problem
Old Apr 13, 2010 | 07:15 PM
PANIK's Avatar
i was gunna suggest stop "beating" it
its probably your injectors
Old Apr 13, 2010 | 07:16 PM
DoMiStIc_RuSh_06's Avatar
That would be your exhaust
Old Apr 13, 2010 | 07:18 PM
myfakeevo's Avatar
you guys are so ******* gay.
s/c noise? sometimes they make it when they are hot.
or valve lash, im honestly not sure if these cars need there valves re-adjusted like other eco-mivecy, vtecy cars do. i only put 30miles on my car a year, so ill never have to find out.
Old Apr 13, 2010 | 07:28 PM
Pyros777's Avatar
Usually ticking means expanding/contracting metal so I would agree it could be overheating of some sort.
If your intercooler pump is not working, your intake temps could be sky high. I'd check that. Listen for it when you put the key in the ACC position, then feel the hoses for pressure/flow.
Old Apr 13, 2010 | 07:35 PM
Cobalt_Daddy's Avatar
thats just the leafblower cooling down.... haha sorry i can't get enough of this leafblower ****... it's hilarious...
Old Apr 13, 2010 | 09:41 PM
YzRider452's Avatar
Its probably just the exhaust cooling down.
Old Apr 13, 2010 | 09:45 PM
chris88z24's Avatar
Check the IC pump before it performs a check on you and your checking account
Old Apr 13, 2010 | 10:59 PM
skatin_boarding's Avatar
Id go with that^^^
Old Apr 13, 2010 | 11:02 PM
USMCFieldMP's Avatar
Rattlesnake Race Shop
Exhaust piping... without a doubt.
[/thread]
Old Apr 13, 2010 | 11:48 PM
YEW FAIL's Avatar
thanks guys ill look into that
Old Apr 13, 2010 | 11:52 PM
Stock Cat-back does this. Its no big deal.
Old Apr 14, 2010 | 08:33 AM
mrbelvedere's Avatar
sounds like lifters to me
Old Apr 14, 2010 | 08:38 AM
YzRider452's Avatar
i hope hes joking...
Old Apr 14, 2010 | 08:42 AM
PANIK's Avatar
it could be injectors my car has a slight ticking....but the ecotecs have a high pressure fuel system and thats the sound of the injectors kicking on and off.....at least that is what my service desk guy said at the dealership....he said the noise is even louder on the 2.0 it has actually scared people away on the lot from buying them
YEW FAIL's Avatar
im getting a ton of mixed answers
idk which one lol
ill see if i can get a video when it does it and ill post it up
Old Apr 14, 2010 | 08:44 AM
PANIK's Avatar
are u t/c or s/c and is it noticed outside the car or only when its quiet inside the cabin?
wow its a rough morning your 2.0 just looked at where this is posted its probably your injectors
Old Apr 14, 2010 | 08:52 AM
blackbolt89's Avatar
my car does this all the time. its the catback.
Old Apr 14, 2010 | 09:42 AM
ok tell me this dos it make the sound when the car is running at an idle if so its the lifters not uncommon if you beat the **** out of it
Old Apr 14, 2010 | 12:23 PM
Only the LNF (08+ SS's) have the loud injector tick and the high pressure fueling system. The LSJ's don't have that, because they aren't Direct Injection.
idk which one lol
I'm almost positive that its the exhaust.
Do this test:
Go out and beat on it till it ticks, and then turn the motor off. Does it still tick? If so, its your cat-back. Its just the metal expanding and contrasting due to heat.
If it doesn't tick anymore... then you know you have an internal motor problem. Which could be lifter tick. The question then becomes, do you have a proper level of Oil in there?
NO. Only the LNF (08+ SS's) have the loud injector tick.
This...
Usually lifters will tick upon initial start up... and go away. And if they don't go away, they're usually a constant tick. Its probably not the lifters, but it certainly could be.
Old Apr 14, 2010 | 02:08 PM
YEW FAIL's Avatar
its ticks after beating on it(sometimes). it continues to tick on idle.(after beating on it)
wen i shut the car off and restart it again its back to normal.
just clearing that up for some of u
Old Apr 14, 2010 | 02:46 PM
northvibe's Avatar
but does it tick if the engine is off?
like drive, beat on it, shut the car off on the hwy or pull over quick and see if its still ticking.
Old Apr 14, 2010 | 02:53 PM
Pyros777's Avatar
Really need video or audio if you can get it.
Old Apr 14, 2010 | 03:00 PM
it only takes like a minute or less for the catback to cool off. mine stops ticking like 20 seconds after i shut it off.
