Timing
Old Sep 13, 2007 | 04:12 PM
quickspec's Avatar
Timing
Is there anything you can use to control the timing without going into the pcm?
Old Sep 13, 2007 | 04:14 PM
06black's Avatar
you can retarded timing with an AEM FIC.
Old Sep 13, 2007 | 04:15 PM
quickspec's Avatar
How hard is it to hook up?
Old Sep 13, 2007 | 04:25 PM
ridemlow03's Avatar
j/w but isn't it better to advance the timing rather then making it retarded????
Old Sep 13, 2007 | 05:04 PM
Formula96's Avatar
nitrous, more boost. retard timming....
Old Sep 13, 2007 | 05:33 PM
Area47's Avatar
Rent me! per hour
the fic is a piggy back setup.
why spend the money on that, when you can get hpt for 509 bucks, and damn near full reign of the computer?
Old Sep 13, 2007 | 05:38 PM
NJHK's Avatar
That's not necessarily true.
Just because you have forced induction doesn't mean you have to retard timing. It's a countermeasure incase there is some type of pre-ignition / detonation occuring.
This also depends on the stock ignition timing and the type of engine this is on.
Basically I'm saying it's more of a trial and error thing.
umm yeah, what he said
Old Sep 13, 2007 | 05:40 PM
Bika's Avatar
Fail Less.
nope. cant mess with the timing on these cars w/o getting into your ecu, or using a piggyback that tricks the ecu.
Old Sep 13, 2007 | 05:50 PM
Formula96's Avatar
he asked why would you retard the timing, so i gave some ifs and mights...
Old Sep 13, 2007 | 06:11 PM
flathead0's Avatar
were could one find the hpt
Old Sep 13, 2007 | 06:15 PM
Area47's Avatar
Rent me! per hour
www.hptuners.com
Old Sep 13, 2007 | 06:39 PM
quickspec's Avatar
I have a gm stage 3 pcm, so there is no way to get into it, im running a 50 shot, but I wanted to build the motor and run a 100 wet shot, but I herd you had to retard the timing. So that aem fic will or will not work?
I thought they made something that is plug and play like a MAFT that will control timing?
Old Sep 13, 2007 | 09:38 PM
06black's Avatar
he said he dident want to touch the PCM this the FIC idea.
Old Sep 13, 2007 | 10:53 PM
NJHK's Avatar
oh ok gotcha.
Wasn't meant as an attack, just took it in the wrong context.
Old Sep 14, 2007 | 03:45 PM
quickspec's Avatar
So the AEM FIC should work?
Old Sep 14, 2007 | 04:33 PM
Area47's Avatar
Rent me! per hour
lets back up a second here
what are you trying to achieve?
Old Sep 14, 2007 | 05:12 PM
quickspec's Avatar
Im trying to find something that will control the timing for the a gm stage 3 pcm, because I want to up the shot from a 50 dry shot, to maybe a 75-100 wet shot, after I get pistons.
Old Sep 14, 2007 | 05:21 PM
Area47's Avatar
Rent me! per hour
okie dokie. gotcha
06MetallicBalt
Jul 20, 2025 08:47 PM
Fearedbynone
Apr 14, 2016 03:25 AM
biniecki
Oct 25, 2015 02:23 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
